Upgrade 991.2 Door speakers?
So I have been reading as much as I can find on upgrading the Bose system in my 991.2 GTS.
Couple great threads on here for sure.
It appears the Musicar tweeters are a forum-approved tweeter upgrade that is relatively easy and has an significant improvement.
Well, I want to take the door panels off, apply dynamat, and upgrade the door woofer and midrange as well.
I want to see what people would recommend for a quick and painless upgrade?
NOT currently looking to install expensive new amps, or run a lot of new wiring. Cutting wire and soldering doesnt scare me. But the cleaner the install, the bette.r
I've seen on other forums people talked about upgrading to the Burmester speakers. Available from Suncoast.
Has anyone out there upgraded to the Burmester woofer and midrange? Thoughts?
Are there any other options to consider?
I hear there are VW connectors to make the install easier?
Anyone who has made these door speaker upgrades care to shed any tips?
Thanks all
Thanks all
Thanks all
Thanks all
Reach out to Nick at Musicar for the best solution. He is experienced and has the best advice and recommendations.
I upgraded mine with Focal's. If you have access to a router it's not to difficult to copy the outline of the original speakers to make new mounting plates.
Installed the 2 way crossovers for the mids and new Focal tweets under the passenger seat. Running active signals from a Mosconi DSP to the crossover and midbass in the door from Focal amps. Also treated the doors with soundskin, very worthwhile.
What did you use for the foam around the speaker?
Awesome. Looks very clean.
Curious how you did the wiring with all of that.
Did you use any prefabricated wiring harnesses from anywhere? or just cut and solder the wires individually?
I haven't yet taken the door panel off, so I am not too familiar with the wiring yet.
I went ahead and ordered the Burmester mid and woofer for the doors.
Focal K2 Power 4inch for speakers. I guess I understand if you don't want to go crazy with amps or wiring, but if you replace speakers, don't get factory stuff. And possibly consider getting a DSP, won't lie does not meet your not much wiring requirement, but will make a huge difference, I went with JL Audio TwK, FiX. I'll stop there but if you have any other questions feel free to PM me, good luck.
Put the crossovers in the conveniently left space under the passenger seat where the stock amp would go.
The two Focal amps and DSP are in the frunk.
Why? What problem are you trying to solve? Why do you think slapping on new speakers will make it sound better? Are you a pro that knows about how to implement car audio? I think you should take it to a good shop...you're heading down the wrong path.
Platinum Sponsor
Thanks all
Thanks all
Pretty good with these in the back powered by an FPX 1.1000...
Thanks Nick, sent some time playing with an RTA, got it sounding pretty good to my ear but sure it could use a professional tune up.
