Vektor Performance - Performance Headers
Former Vendor
I will grab some the next time we have the car on the lift (soon) so I can get a good shot across the flat bottom. They are lower than factory, but not the lowest point. You'll smack a few other things (including the rear subframe support) before impacting the header tubes.
Former Vendor
I've not seen a GTS plot yet, but given the improvement in VE, power increases will scale with power output. In short the GTS, or any modified setup, should have higher gains than the lower trim levels and otherwise stock setups.
Former Vendor
A customer shared a few photos and data with us. The car already had installed: AMS ICs, IPD plenum, BMC air filter, catless downpipes, and Akrapovic exhaust. The car does have a tune.
During the dyno, only a large central fan was used. No blowers for the ICs.
Some header glow from a dyno pull. This picture illustrates why we choose 321SS material for maximum durability.
It should be noticed again that no fans were used for the ICs. As more dyno data is coming out for the 991.2, it seems apparent the ECU limits top-end power if intake manifold temperatures get too hot due to a lack of airflow over the ICs. The customer has a set of GTS turbos ready to go onto the car to increase the top-end power. In the words of the customer, "The car pulls hard. I'm not sure if the plots show the real deal... but at the track it is very consistent."
Is there any chance of getting a sound clip of this car. Its similar to what I am building. I have the IPD plenum and the AMS Intercoolers. I have my COBB AP but tune not on yet and I am thinking Vektor Headers and AKrapovic exhaust. Mine is a GTS. I would love to here this customers car.
Former Vendor
We posted the video to our Facebook page.
You can hear how quickly the turbos spool up once the throttle is applied to start the dyno pull.
Well, this looks all kinds of awesome:
Canes78 (08-07-2019)
Finally they posted a pic on FB. Does anyone have any experience with the white ceramic coating? I know the metal ones look cooler for 10 minutes. But as most headers they go almost a rusty colour. I figured white may look better, especially as I have a white car. I know you don't see them much. Any thoughts on performance?
White ceramic coated Vektor Headers
http://swaintech.com/race-coatings/r...aust-coatings/
Im wondering if Porsche designed the header to allow heat to escape or if keeping the heat contained within the pipe is desirable. Dont know enough about the design of headers but, apart from being white, do we want to contain heat or let it dissipate naturally?
Here's good info on using just a turbo blanket. Same idea, keeps the heat in the turbo. Also, look at every motorsports turbo engine (F1, Le Mans, WRC, etc); they all have serious insulation on the headers.
https://motoiq.com/nerd-o-scope-keep...urbo-blankets/
When it comes to turbocharged cars, heat = energy. The more heat you keep in before the turbo, the more energy there is to spool the turbos faster. If you dyno a car with 'cold' headers vs. the same car that already has the headers warmed up, the dyno with the pre-warmed up headers will show faster spool. This is because the cold headers (relatively speaking) will suck heat/energy out of the exhaust before it can get to the turbos.
Just look at some modern day designs. Manufacturers are trying to get the turbo as close to the block as possible. Some manufacturers (Volvo, I think VW, and possibly others, have actually made the exhaust manifold part of the block in order to retain as much heat energy into the turbo as possible. Here's a good article, with a link to a video by Engineering Explained:
https://jalopnik.com/automakers-are-...lds-1796305029
So no, keeping exhaust into the turbo isn't a bad thing.
