Zunsport grills...bent tabs REALLY?
Contacted Zunsport (Peter) and he is perplexed.....almost doesn’t believe the photos. I pointed him to this tread as “I’m not the only one” with regard to this he center grille.
I would hope that he agrees they shipped/and or recommended the wrong kit for my car.
We shall see...::
We shall see...::
You have the Sport Design front bumper so you need to make sure you get the set that includes the center, sides and small openings next to the sides. Do you have front parking sensors and /or Active Cruise Control ?
I have an "accurate" part count from Zunsport....just not the right set(s). The side grilles are completely wrong, the center is looking for a lip for the bottom hooks that doesn't exist. The only ones that seem to be correct are the two small openings between the center and the sides. I do have parking sensors and no ACC.
It must be a 991.1 vs .2 thing. My 991.2 GTS grills fit perfectly on the first try and less that 20 minutes including time to read instructions. Zunsport has a very satisfied customer here.
I have a 991.1 C4S and my bottom grill off the 3 part set, does NOT fit no matter what I do. Hey, this isn’t rocket science here. I can read and follow instructions. I also watched a video they sent me. And like I said the lower grill does not fit. They are going back.
