Zunsport grills...bent tabs REALLY?
Old 07-07-2018, 09:17 AM
Guzzgreg
Guzzgreg's Avatar
Default Zunsport grills...bent tabs REALLY?
Bought the Zunsport grills for my C4S 991.1 with parking sensors mostly on the recommendation from others on here. Can not seem to get them to fit. I did verify they are the correct ones for my car. Seems as though the mounting/securing tabs are bent the wrong way. Can’t get past the bottom grill. Anyone else have this problem. Do I have to bend them into position? If this is the case they are going back. BTW my wrenching skills are pretty good.
Old 07-07-2018, 09:54 AM
Penn4S
Penn4S's Avatar
Received 1,298 Likes on 729 Posts
I have them which I installed in 20 minutes with no problem. Post a pic of your pieces.
Old 07-07-2018, 10:16 AM
Guzzgreg
Guzzgreg's Avatar
Here are the bottom 2
Old 07-07-2018, 12:25 PM
goldduster
goldduster's Avatar
All of my tabs were hooked like the bottom picture. I put them in place, pushed the grill in and then used a long screwdriver through the grill so they would catch as I released the pressure on the grill. The top photo tabs are different from mine; I have a 2018 GTS, don't know what model your have. They seem to be different.
Old 07-07-2018, 01:14 PM
arter
arter's Avatar
call or text sunsport ( on monday) and see what they say
Old 07-07-2018, 01:26 PM
Guzzgreg
Guzzgreg's Avatar
Mdl. 2013 C4S
Old 07-07-2018, 01:30 PM
freeman
freeman's Avatar
Zunsport folks are extremely cooperative and helpful
Old 07-07-2018, 02:05 PM
Guzzgreg
Guzzgreg's Avatar
Just don’t know what I’m doing wrong. Should I be pushing them in from the front or the back?
Old 07-07-2018, 02:10 PM
SoCal C2S
SoCal C2S's Avatar
I just received my full set from Zunsports yesterday...all the pieces mount from the front according to the video. Now you have forced me to install them this weekend in 105F heat....thanks!
Old 07-07-2018, 02:16 PM
Penn4S
Penn4S's Avatar
They go in from the front and on the ones with the flat tab you need to put a small retaining clip in place one you get them in position. That holds them in position. It’s a little tough to fit but all fits and works.
There are good videos available and Zunsport usually sends install instructions. Yours look right the flat tabs are for certain openings. Didn’t you get instructions and a bag of small hardware?
Old 07-08-2018, 07:50 AM
Guzzgreg
Guzzgreg's Avatar
Got the instructions just can not seem to get the curved tab to catch anywhere so that it holds on to the inner part of plastic on the front lower fascia. Does not want to stay.
Old 07-08-2018, 02:23 PM
SoCal C2S
SoCal C2S's Avatar
None of my Zunsport parts fit! I even send them a picture of the front of the car just to make sure the part number that I should order is correct!
As said by a the OP, the front grille has no place to catch the tab. That and the fact that the side grilles
are just wrong!
I’ve contacted them...I’m sure they’ll make it right.
Old 07-08-2018, 02:45 PM
Penn4S
Penn4S's Avatar
You definitely have the wrong pieces. The slightly curved end is for you park assist module. Are you sure you ordered for your particular model? The model list on the website can be confusing. I’m sure they will make it right.
Old 07-08-2018, 03:00 PM
Guzzgreg
Guzzgreg's Avatar
I checked 3 times To make sure I ordered correctly as that is the first thing I thought. I was sure I ordered the wrong parts, but no the pieces seem to be the correct ones with the exception of that curved tab with no place to hook it.
Old 07-08-2018, 06:07 PM
SoCal C2S
SoCal C2S's Avatar
Like I said....I sent Zunsport a picture of the front of my car just so they can tell me which part number to buy.
Seems like that didn’t work either!
Quick Reply: Zunsport grills...bent tabs REALLY?
