991.2 Carrera S brake upgrades to GT3 380mm
Is it possible to install brakes with GT3? The whole set ( Brake Rotor 380mm, calipers +pads)
Plug and play or I need to change something more?
Thanks in advance for your help.
Technically.. there are many part number differences.
From Brake booster, Uprights, and more between PCCB and Non PCCB cars.
Check out brembo for a 380mm upgrade set / are you past your stock brake limits ?
I meant iron rotor.
Stock brake finished and I have option to buy a GT3 brake set at a good price.
I found topic:
https://www.6speedonline.com/forums/...ml#post4222856
991 C4S + calipers and rotors from Turbo 2014 - the same as in GT3. The question is whether it will be the same with 991,2 C2S ?
I found topic:
I meant iron rotor.
I found topic:
I found topic:
Dang Squires..your car looks awesome...the stance and those wheels...yeah those wheels are perfect!!
