INCOMING!!! Oil thread
Old Jun 26, 2018 | 07:59 AM
mreloc's Avatar
mreloc
Default INCOMING!!! Oil thread
I just love to read oil threads, don’t you?
Anyway, back in my 997.2 days, I switched to Motul Xcess 8100 5W-40 oil because I live in LA and the warmer temps warranted a slightly heavier weight. The highly respected LexVan has a preference for Mobil 1 5W-50, another Porsche approved oil that also makes a lot of sense for warmer climates.
Anyway, moving to my 991.2, I’m again weighing my oil options. Surprisingly, the long piece posted below has ranked the current “FS” European car Formula Mobil 1 0w-40 impressively high in its protective capabilities and relatively high resistance to thermal breakdown. I believe this revision to this 0W-40 oil formula was made in 2016. Any thoughts on the validity of this analysis? It seems thorough..
https://540ratblog.wordpress.com/
Old Jun 26, 2018 | 10:31 AM
Quadcammer's Avatar
Quadcammer
That blog link has long since been debunked numerous times.
If you arent tracking the car, 0w40 is perfectly fine. in a hot climate, a mix of 5w50 and 0w40 or all 5w50 would also be good
Old Jun 26, 2018 | 10:50 AM
trucheli's Avatar
trucheli
I am more inclined to trust Porsche and Mobil 1Engineers than a blog online. 0W40 is the selected oil for a reason. It's a good compromise for cold weather and warm weather climates as well as gas mileage consumption.
Old Jun 26, 2018 | 10:59 AM
mreloc's Avatar
mreloc
Maybe I didn’t make my point clear- the blog has a very strong affinity for the Mobil 1 0W-40 vs the 5W-50.. therefore my question since typically I would expect the 5W-50 to hold up better.
Old Jun 26, 2018 | 11:27 AM
golfnutintib's Avatar
golfnutintib
ugh
Old Jun 26, 2018 | 11:58 AM
Mike Murphy's Avatar
Mike Murphy
Motul and M1 are both good, but I’m guessing Motul would be slightly better. I would just stick with Motul at this point.
I can’t comment on M1 50 vs 40, but have heard that the formula can change and be different. So to avoid that issue, again, I’d stick with Motul.
If you are tracking, one thing Motul has over Mobil is anti-foaming, which I think is important on the track.
Old Jun 26, 2018 | 12:06 PM
Mike Murphy
Heavier weight of 50 might hold up a bit better in terms of resulting pressure due to higher viscosity, but it could also retain more heat energy at the same time.
There is no benefit in LA stop and go traffic for higher oil viscosity due to temps because you don’t have enough localized heat in the engine because the engine isn’t making any real power. So the pistons and valves and cylinders aren’t really that hot. Overall, the entire engine might be warmer, but it’s the radiators and coolant that now needs to remove the heat.
Now, if you are driving in a spirited fashion or on the track, the engine is generating much more localized heat that requires the oil to cool it down, 5-20x the power delivered and 60-80% more heat, followed by the coolant now needing to remove the heat from the oil. That’s where you will see higher oil temps and where you will need the higher viscosity - under significant load.
TL;DR - You don’t need higher oil viscosity on the street for driving in traffic and/or highway.
Old Jun 26, 2018 | 12:35 PM
Z00mie's Avatar
Z00mie
Say it with me! MOTUL.
Old Jun 26, 2018 | 12:52 PM
JW911's Avatar
JW911
0w40 and 5w40 are exactly the same viscosity in the hot summer weather. The only difference is the 0w has lower viscosity and flows better in very cold weather. Which has nothing to do with hot LA summers. So if you are seeking higher warm weather viscosity, only going to the 50 will accomplish this.
Old Jun 26, 2018 | 06:09 PM
LexVan's Avatar
LexVan
Originally Posted by Motul
We do make an ester grp 5 based 100% synthetic oil called, Motul Sport 5W50. People here have been using it with good success as well if you do go down that route. Let us know if you have any questions. -Nick
Nick, can you post a VOA for this oil?
Old Jun 26, 2018 | 06:31 PM
mreloc's Avatar
mreloc
All- I’m not really looking for this to be a “what’s a recommended oil” thread as much as I was trying explore what are pointed out as the various positive attributes that come newer version of the M-1 0W-40 (at keast as presented in this article) if it’s bull****, then fine, but if there’s any validity to it, then it protects far better than the other oils mentioned on this thread- regardless of operating climate.
Old Jun 26, 2018 | 08:47 PM
mreloc's Avatar
mreloc
Thank you, Nick! Helpful info.
Old Jun 26, 2018 | 09:55 PM
SoCal C2S's Avatar
SoCal C2S
Oil thread?....Oh please!
Just use Motul 8100 5W-40 and get on with it!
Lets talk about tires! There’s a non controversial subject....I’ll start, I like the round ones. How about you?
