Mirror stopped dipping in reverse, dealer says $15K
#31
Thanks for all the replies! I was frustrated when I wrote this out last night. Keeping fingers crossed it is just a switch. I’ve had other relay switches fail since I’ve had the car (sport exhaust and cabin heat relay switches), but that was under warranty. It seems so much more likely it's a switch again.
If anyone is in Northern VA and has an independent Porsche guy they like or recommend, let me know. Otherwise, I will hit up ASG in Falls Church (http://autosportsystems.net/) to look at it. They seem good. In the meantime, I will just be more careful backing up. I drove my 911 to work today and it’s beautiful as ever to drive, it just does not have a mirror that dips down (no big deal to me) or functioning reverse lights (admittedly, kind of a big deal). I will keep you guys posted.
A quick question for those with MT -- you know the little window in the dash that says what gear you are in? What does it say for you when in reverse? Mine has a “1” in the window when I put it in reverse and fully let out the clutch. I’m surprised it isn’t an “R,” but I never noticed before because usually when I back up, I’m never actually in gear long enough to notice anything in the window. Just wondering what others see.
EDIT - not sure I should say who the dealer is, because they have been nice to me in the past. But it's a large dealer here in Northern Virginia. I'm going to hold off on my survey response (and "outing" them) until I know if they really were asking $15K for a <$100 issue.
I have been using them for more than four years for service with good results but I do have a PCA friend that won't step foot in their showroom until Hell freezes over.
#32
Subscribed for the outcome. After reading this thread I'm trying to remember if the mirror dips on my car (also 7MT), and I don't recall it ever doing that! Will double check when I get home. If it doesn't, I'll buy a switch and install it myself.
Viper pilot (01-12-2021)
#34
I booked time to bring my car in. Unfortunately it's not for 2 weeks.
#35
Also check if your reverse lights activate, I think if its just the mirror and the reverse lights come on it could be a programming thing. But if both the mirror does not dip AND the reverses lights don't activate it could be the reverse switch. ALSO my hill hold stop functioning, I wonder if this is all related?
#36
I think it is highly unlikely that replacing a simple switch would require the entire transmission to be replaced. I know engineers have made design errors before but this one just doesn't make sense to me.
Same with 991.1/.2
#37
Especially with a part that is a common failure among all manual transmissions.
#38
Talked with a Porsche Gold Tech. He was cracking up at the point of a new transmission. There aren't even any internal switches in the tranny!
He said most likely a software or coding issue. There is one switch maybe by the clutch? Was having a hard time following as I'm not a huge tech guy. For the mirror turning downward, make sure the setting is correct for that. There should be a setting in the PCM for that.
Overall, this dealer is full of SH*T!
911Raider (06-10-2022)
#39
#40
#41
Just putting this here for reference, as you can see, there is in fact a backup switch towards the front of the transmission Part #3!! I added a pic of an actual 991 Manual. This is the 6 speed from a 911R, but I assume the enclosure is pretty similar if not identical
#42
#43
Just going to put it out there - but if the cause *is* a problem with a switch on the internals of the transmission, and the effect is no reversing lights -- then this is a situation where you open a case with the NHTSA here: https://www-odi.nhtsa.dot.gov/VehicleComplaint/, and then let your dealer and PCNA know you have done so. Need for a recall campaign would almost certainly be investigated as this is a safety issue with a late-model vehicle.
In most (all?) states, you can't pass vehicle inspection without reversing lights.
All that said...this is almost 100% a failed microswitch on the transmission housing. They should be replacing it for no charge (again, because its a safety issue with the reversing lights not coming on, and the driver not being aware of that fact).
cheers!
cheers!
The following 2 users liked this post by 911-TOUR:
maschinetheist (10-13-2021),
PatrickBateman (07-11-2021)
#44
Received 1,543 Likes
