Center-lock wheels - locking pin engaged?
Yesterday I removed the center-lock wheels for the first time on my new 991.2 GTS coupe and reinstalled them today. Two things that I was questioning:
1. When removing the really small hub caps I noticed the locking pin was not engaged on one wheel? Came from the factory that way … as I assume the dealer had no reason to touch the center-locks during deliver. Wouldn’t locking pin engage if the center-lock nut started rotating?
2. Got to use my new Precision Instruments torque wrench & breaker bar for the first time … per the instruction in the 911 Owner’s Manual. After the tightening & 1/4 turn back-off, then re-tightening … 3 out of 4 locking pin were not engaged. The 911 Owner’s Manual indicates checking that the locking-pin has automatically engaged. If not, use your auxiliary tool (left … right) unit it engages. They all engaged with a small loosening rotation? (maybe a 1/32 rotation or less rotation). That would be something less than full torque (443 ftlbs on my GTS)? Assume that’s OK?
I have also been having fun personalizing my new 991.2 GTS coupe for the last 3 months and I am running out of ideals.
Here is a short list of updates:
Locking pin engaged
- Added Guards Red pin-stripe to the outer lips of wheels like the GT3 option. Adds a visual separation between back tires and black center-lock wheels.
- Added outside ZunSport grills to protect the radiators.
- Added XPEL ULTIMATE, Paint Protection Film protection: front bumper, full hood, full fenders, mirrors and headlights + rocker panels + front & behind the rear wheels + door handles + windshield pillars.
- Added Personalized Plates … B4 2 OLD … “Before to old to enjoy a Porsche!”
- Reduce the verbose “911 Carrara GTS” on rear to just “GTS”
- Removed the red pin-stripes & painted the black center-Lock wheels a “Black Gold” color. For better balance visually.
Locking pin engaged
After you back it out 1/4 turn, and retorque, just push pin in until it engages and pops out flush. I don't think you should loosen it 1/32 from full torque.
You're torquing them with the wheel off the ground, correct?
Edit: You guys are fast, same as above..
Thanks again, I can take drive today without worrying about the center-lock wheels.
Don’t loosen Center lock to engage locking...you will no longer have correct torque. Just grab a 1/2” socket drive extension and insert it in the lock with a slightly wiggle and ithe lock will,pop,out.
Thanks ... I now understand how to get the locking pin to pop out. I had just miss read the owners manual the first time around.
When I raised the car up again to torque the center-locks back to the correct 443 ftlbs, I found the auxiliary tool worked as the other guys suggested.
