Airbag and seatbelt warnings followed by start/stop operation deactivated
While driving on I-35 on a hot day (~94 deg F), I noticed sudden airbag/seat belt warning lights on the dash.
About 15 min later as I was exiting the highway, I see the auto start/stop deactivation warning message with a big triangle.
I searched for both messages appearing in sequence, but was able to find one or the other, but not both.
Since my car (2012.5 991.1 C2S) is still under CPO warranty, I will call the dealer first thing Tue, but has anyone run into this situation? If so, what was the solution? Battery? Blown fuse? Bad sensors? Thanks.
Received 5,388 Likes
I'd say battery is a good guess.
I bet it's the Airbag Controller. Mine just failed last week and had the same results. (Airbag warning, no auto start/stop, no cruise). It's at the dealer now awaiting the part being mailed from Germany.
FWIW - mine is a 2018 C2S w/ 5K miles and is three months old.
From my experience this is classic dying battery. You are on borrowed time anyway so why not go ahead with replacement. Easy fit. Search the forum for battery and install info . I have used Wal-Mart for my 2 911's and Cayman.
With regards to being on borrowed time with a failing battery, that was my first suspicion after the start/stop warning. I am hoping that my CPO warranty can cover either or both situations given that the car has accumulated > 6K miles/year.
Thanks for all your responses. I will keep you informed of the status once I make a service appointment (oil change due anyway) and hear back from my SA at Porsche Austin.
In my experience as the battery is getting old, you get a lot a pcm/lcd etc gauge blinking when you crank when the battery is ready to be replaced and stay solid when your battery is good so easy to tell before it goes kaput.
I agree that the battery health can deteriorate in a nonlinear fashion. This car has been to the dealer at least once a year since born and no issues with the battery/charging system have been found so far. Even now, the car drives fine with the starting voltage of 12.0-12.3 and the charging voltage of 13.5-14.3 depending on the length of drive. Anyway, the service appointment is on June 15. I will keep everyone updated.
Got the car back from the dealer today. Their diagnostic work summary:
- Battery healthy
- P1603 - airbag triggering fault
- P1265 -- crash signal not working
- Faulty airbag control unit replaced
- Start/stop working after replacing airbag control unit
thread resurrection
hi
i have had exactly the same today. did about 15 miles this morning which were all fine, and then 5 miles into the return journey while on the motorway in traffic the airbag and seatbelt lights came on, a few mins later when i pulled up at lights got the stop/start deactivated alerts which i had never seen before. it was warning as opposed to the sign indicating not active because of cold engine or low battery
the battery was replaced a few weeks back, but its not had much use the last few months over winter.
Probably related to this is that the fuse in d1 labelled in the manual as airbag control unit was blown, and blew immediately i put a spare in - quite properly as i saw it pop with a nice flash as soon as i turned on the ignition which suggests something rather broken.
to the op @kilster was there anything else that came up when you had this? or just the control unit needing replacing, which sounds like a job for the dealer to me.
btw. this is a 2012 manual c2s if it makes any difference, but i'd guess this sort of part is the same on all of them.
thanks
hi
thanks
In my case, no fuse was blown. The dealer replaced some control module and reset the error codes. It has been fine since then. The battery is still good with CTek connected to it once a month, requiring around 3-4 hours for the green light to appear.
Off to the dealers I go.
airbag control unit
hi
turns out it was the airbag control unit,which seems identical to the other occurrences
about £600 for the part and £600 in labour to confirm this, replace and code the new unit as the car is well out of warranty.
had the battery replaced a couple of weeks previously, no idea if its related, but all seems okay now.
