Question regarding 4S .2 front wheel well clearance
How tight is the space inside the 991.2 edition 4S front wheel wells? I ask because I am considering fitting 19-inch wheels and tires in an attempt to reduce the risk of potholes munching tires and bending wheels. Michelin Pilot Super Sports are available in 265/40-ZR19 and 305/35-ZR19 that have virtually the same rotations/mile spec (760 vs 758) front and rear. Will the slightly wider & taller 265/40-19s have clearance issues with the 4S's front wheel wells or suspension gear in full turns or bumps? For reference, the overall diameter of the 265/40-19-inch PSS is .6" more than the Michelin Pilot Sport 4S in 20 inch that are spec'd for the 4S; is there sufficient clearance to consider the 19-inch PSSs?
Thanks in advance to all who post.
