What is the proper torque for engine oil drain bolt?
Hi. I'm new to this forum, just sold my M4 and moved to 2013 911 991 C4. < GREAT CAR!
I'm about to DIY my oil changes, as well as air / cabin air filters.
My selection is Mobile 0W40.
Also, will it be to low for Florida weather?
Thanks guys
Thanks guys
Received 5,413 Likes
The torque spec is 37 ft.lbs. Using a new crush washer.
Oil filter cap is 19 ft.lbs.
The cabin filters are very easy, just have to be a midget contortionist for the one under the glove box.
Mobil 0W40 is Porsche A40 approved. Mobil 5W50 is too, and a good selection for your Florida heat.
Welcome to Rennlist!
Wow this is great thanks
In 991.1's
Oil drain plug to oil pan -- M18 x 1.5 replace sealing ring -- Tightening torque 50 Nm (37 ftlb.)
I don't know what the 991.2's are with the plastic oil pan.
991.2, just tighten until you hear the click. It'll be obvious once you do it. Standard on a lot of newer German cars with plastic oil pans.
Originally Posted by Contadino
My local shop told me 37 was too high. Said they use 19 ft-lbs. I know that is what the manual says but....
