Replacing battery
Old May 30, 2018 | 12:58 PM
mymac's Avatar
mymac
Default Replacing battery
Will I lose all my presets and memory settings when I swap out my battery
Old May 30, 2018 | 01:03 PM
Pmorritt's Avatar
Pmorritt
Some say yes some no. Or, hook up your battery tender or I have a cigarette lighter plug with a 9v battery attached (get it on eBay) and you should be good. Worst case you would have to reset radio and windows.
Old May 30, 2018 | 02:14 PM
Sidvicious7's Avatar
Sidvicious7
I replaced my battery a few months ago, and I didn’t lose my preset channels. I also added the ashtray to my vehicle in January and i had to remove my PCM to gain access to the harness for the ashtray upgrade; the radio was left disconnected on my work bench for several days and when I reinstalled the PCM it retained “ALL” my preset channels. In summation NO you shouldn’t lose the preset channels on your PCM.
Old May 30, 2018 | 02:27 PM
Porsche_nuts's Avatar
Porsche_nuts
Yeah, don't think you will lose them. Only thing I have heard is that you may lose automatic window control, but that is an easy fix.
Old May 30, 2018 | 06:18 PM
mymac's Avatar
mymac
Thanks for the info.
