PSE button
Where can I purchase the PSE button for the console? I am installing a Fabspeed Valvetronic exhaust on my 2016 911 Turbo, and I would like the PSE button if possible. How can I get it without buying the whole PSE unit?
I just DIY installed PSE onto my car. It's not possible to purchase the button by itself per Sunset and Suncoast parts. Unfortunately you have to buy the whole center switchpath based off of your VIN so it will work with the options on your car.
button
What do you want the button to do ? If you want the button to open and close the valve then you just call them with your vin. If you want it merely for appearance just go to a recycler like the dismantler in CA.
suncoast
Call Suncoast tell the what you are trying to accomplish. As mentioned earlier the dealer will need to program the computer once button is installed.
The OP hasn't logged in to Rennlist since 2018. I don't think they'll be able to answer that.
A functioning PSE button requires an entire new console button housing ordered with your VIN from an authorized dealer. Then after install the new console with the PSE button added, the car must be programmed at the dealer. Also, you must be sure that your exhaust is connected to the proper vacuum lines.
