Change over valve and PSE while they're in there?
I'm bringing my 2014 4S to my local dealer tomorrow for what I believe will be a changeover valve issue (car is under CPO warranty). I got a "Fault Cooling System; Visit Repair Shop" warning yesterday.
My car doesn't have PSE, but it's on my list of eventual upgrades. Questions:
- Will there be any financial benefit to adding PSE while they're doing the fix for the changeover valve?
- Is there any way to get the dealer to NOT install or charge me for those silly exhaust tips that come with the PSE package? Aren't they $900 worth of nothing? I know you could argue that the whole PSE is $4000 worth of nothing, but I want the sound, not the tips!
The tips are another size/spacing than the non-PSE ones, so you can't reuse the old ones. If you break apart the PSE "kit" and go a la carte, the broken out price of each item is much higher.
I forgot to advise about the other part of the question. It depends on which change-over valve they are addressing as to whether or not there would be any potential labor cost savings. I'd just ask the dealer what kind of a price break they might give you rather than ask for our opinions here. Ultimately they are the ones that will decided whether or not to give you a break to get the "sale". It's likely to late anyway since I doubt they keep PSE systems sitting around in stock.
I know they say one symptom is that the HVAC system stops throwing heat. (I will check for this when I get home)
Another is that the exhaust note starts to sound different. (I do think this is happening, although it's tough to tell - I've only had the car for a few weeks)
I've read otherwise re: tips. Check out this thread. It's all good info, but the part about the tip fit starts on post #60. That thread also talks about a la carte being cheaper. Why is a dealer locked into a "kit?" Shouldn't they be able to install whatever pieces are necessary? Does Porsche only sell it as a kit and dealers don't have access to the necessary parts otherwise?
And again maybe I'm wrong about the tips and am remembering the 997.2 tips. They certainly had different sized outlets for the loud pipe and the more muffled pipe.
I guess maybe I should just be quiet now and let someone else that did a PSE retrofit on a 991 speak up. Sorry for the potentially misleading answers... I'll be quiet now
if you noticed that the exhaust note starts to sound differently, then it could be the vacuum line is loose. i'd check the passenger exhaust valve and vacuum first as this one is usually the culprit.
Call Sunocast Same Size
If you have the S model the tips are the exact same size, I had the guy at Suncoast measure. All you need is the replacement center muffler the side mufflers are the same. You also need some misc bits and the switch. Go to an indie for this and save 2K.
Nope
Nope
Tubi Style. That is all
[QUOTE=Bud Taylor;14931248]If you have the S model the tips are the exact same size, I had the guy at Suncoast measure. All you need is the replacement center muffler the side mufflers are the same. You also need some misc bits and the switch. Go to an indie for this and save 2K.
+1 on this.
I just installed the PSE onto my car the other weekend (a post to follow with some tips from my experience to follow after the dealer programs it). According to a German, the tips probably don't fit. But the $1000 I saved says otherwise. I'm as **** as they come, and the tip does have enough of a gap where if you shine a light from the engine towards the rear of the car, you can see light coming through the gap between the muffler and the tips. I hear you can probably adjust to fix it, but for all intensive purposes, it fits. You can only see this gap if you are at ground level, and an light is shining directly behind the tips. If someone has an extra grand they want to throw it my way. The Top Ramen diet I've had to live on to afford this car is starting to get old...
+1 on this.
The S tips do have close to a 1/2" gap on one of the two tips where they connect to the muffler. The inner ones on each side that don't have a clamp. You don't get 100% closure and a seal for the exhaust out the tip. Some exhaust is escaping and going under the bumper.
I had my PSE installed two years ago on my C4S. The dealer tried to convince me that my stock tips would not work. But based on my internet research I asked him to double check. Twice. Eventually he agreed and did the install without the expensive PSE tips. As for the above comment about a gap. That's the first I am hearing of this and I have certainly never noticed any such gap. If it is there it is invisible and thus I appreciate the $1000 I saved.
One thing to note, my stock tips are the optional "sport" tips which are chrome and as I understand it they are nothing more than chromed versions of the regular SS tips. They were an $800 option on the original factory build. (not my build!)
Got my car back this evening. As kevincarreras predicted, above, it was a loose vacuum line. Fixed quickly and without incident, but also without any potential savings for a PSE install... so no PSE for me! At least not yet.
As an aside, I also mentioned my horribly creaky sunroof. They said that the current service bulletin requires a specific grease to lube the mechanism which, of course, they did not have on-hand. Instead of waiting for it to be ordered and delivered, I opted to bring my car home and live with it until the next time I need to bring it in.
There is also a weird issue with my interior rear view mirror which has a sort of hazy hue to it. It's not crystal clear. I mentioned it to the service rep, but they didn't do anything to fix it and I forgot to ask about it. Any thoughts what this might be? I'll probably start a new thread about it, especially if I can somehow snap a picture of it.
Suncoast
The guy at Suncoast says they are identical dimensions when measured with a Micrometer so I'm not sure you have a data point ? Mine fit perfectly and looked to have an identical gap (we measured, albeit with a tape).
