991.2 GTS front lip Paint Code ?
Gonna get my other lip painted( damaged one) to have back up. Anyone know the paint code for the matt black? Im assuming it doesnt matter matt black is matt black. But would like to do it OEM. Thanks.
actually might be Satin black. Has a sheen to it.
Received 4,134 Likes
Most of those lips are are not painted, they are just black ABS. If its scraped lightly you can just sand it down using fine grit sandpapers and work it up to wet-sand 1200, you won't be able to tell it from new that way.
If you decide to paint it - just rattle can it after prep, any satin black is going to do. As soon as you scrape it again though - the paint will crack.
Yea i know they all come primered whn you order one. So def has to be painted. Even from suncoast they come primered. Any Satin black should be fine I assume.
hes saying the black plastic is bare. It is not painted or primed. If you want it painted, which is better because it will whiten and get wax in it and look lighter with age, you can sand it and paint it with any satin or black paint. Or best is SEM bumper coater which is meant for bare black plastic parts.Or you can take it to a body shop and have them prime it and paint it with the car color
Ok cool. Thanks guys!
