Tire Pressure Question
Hey Guys. I’m running 36/44 cold on my 2013 C2S with 20” Sport Technos and OEM Pirelli P0s. I like the ride. I don’t find it too harsh, but perhaps I can improve the handling at lower PSI?
What are your thoughts? I drive in a spirited way on dry N. Ca roads.
Thanks!
Thanks!
I run 30/33 cold; the "comfort" pressure for 4S. Heats up to about 33/36 usually w street driving, which rides and handles fine.
I think 44 cold is way too high. If you put some heat into those rears you'll approach the high 40s, and w these tires max psi it can safely hold is probably in the low 50s.
I use the comfort settings for a better ride. Probably more flex in the sidewall but I doubt I would be be able to detect a difference in handling in street driving. Actually I can’t.
Regular settings with the P zeros are harsh for me. I don’t need the top speed the car is capable of. And I am OK with a slightly shorter life for the tires. .
The best overall performance is closer to the so-called "comfort" range of something like 30/35, 33/38, something like that, HOT. Cold does not matter. Whatever it is cold that results in that when hot, when you are driving, that is what matters. Also whatever 911 it is does not matter. Tires, that DOES matter. Some tires work better a few psi higher or lower than other tires. No street tires I'm aware of work better at 45. That is just out there.
Porsche has always specified a pretty big f/r bias of 5 psi or more. Some of this is necessary because of the 911 rear weight bias. But then they add in even more to bias towards understeer, because they know their customers don't know how to drive. Understeer is always deemed safer for unskilled drivers. That is why you will see the more experienced drivers recommend pressures with a smaller f/r bias, often as little as 3 psi. But really, anything around these numbers is well within your personal preference.
Received 1,691 Likes
Here - https://rennlist.com/forums/991/1057...-purposes.html - we beat the crap out of the tire pressure topic a couple of days ago.
Received 4,385 Likes
There is only ONE correct tire pressure to use on the street - that's the one that gives you even tire wear.
Part-load Comfort Pressure is the 'go-to' pressure. See above linked thread for dead horse beating.
Just took delivery of my car the other day and the dealership set the pressure at 36/46. It took approx 5 minutes to determine something wasn’t right when I got onto a road that wasn’t very smooth. The ride (from the back specifically) was harsh and the sound over bumps was similar to that of an overinflated basketball. After reducing pressure a few lbs in the rear only, everything felt normal (ie: similar to my 981 when pressure was on the high side). I too have now set pressure to partial load/ comfort and will adjust accordingly as cold temps outside increase to something considerably north of a few degrees above freezing.
I have a widebody car with 245 f and 305 r. I run 31 f and 35 r. Car rides extremely well, handles perfectly and I always watch and get even tire wear. No need for daily driving to run high pressures like 36f and 46r unless you have 4 meaty passengers and their luggage.
