Long winter, wife's thinks I'm losing it
Originally Posted by subshooter
That is really cool. How did you do that? Can you order them with monikers on them?
I wear Stan Smith's normally so not much of a stretch.
Bonus points for those who figure out the white figure in the blurry reflection of my red sweater
Love our Technivorm as well. We've had our unit for 4+ years and it still works flawlessly in daily duty... ours is the CDT model below which I think looks slightly nicer. If you don't have it highly recommend the Brew-Thru lid... helps keep your coffee warm even longer.
Originally Posted by R_Rated
Careful - we might get nominated for best threads
So... This thing is certified by coffee tasters association in US and Europe. That is hard to do. It has a Copper heating coil and is hand made in the netherlands. It will last forever. Makes an entire perfect pot in 4 minutes. Like an auto pour over with the design. The only control is an on/off switch. Simple and effective.
Compared to a french press - French press should be @ 190 degree water for 4 minutes. This brews at 200 degrees. It starts hotter and stays hot in the excellent yeti quality carafe. It's hotter and cleaner with less residue[pulp] in the cup. Also the grind setting should be much finer in this for drip. Also, I may be about to change your life.... If you're not using an Espro French press and a descent grinder then get one today. Bodum is a gateway french press. We do french press on the weekends. The Moccamaster is just so easy to run and clean between pots.
Ok, now I will return the favor: these are the bomb when it comes to drinking coffee on the go:
https://www.joulies.com/
In the market for new coffee maker.
How is the technivorm for everyday cleaning?
Can you brew 3 large cups easily (I drink one, hubby drinks two usually). Estimating a total of 30 ounces.
Didnt expect to to get a coffee maker referral when I tuned into this thread!
http://www.chemexcoffeemaker.com/ott...ffeemaker.html
My Technivorm makes 10 cups which is really 3 good sized mugs of great coffee. I am a La Colombe coffee drinker, Nizza or Corsica, fine grind.
Love how this turned into a coffee thread. Almost as good as the thread about putting fragrances into your console change cup.
