Porsche Vehicle Service Protection Platinum Extended Warranty?
#31
Anyone know how Fidelity works, re: when the plan actually starts? I got a Fidelity quote and the broker said that the plan starts on the DAY I get it. So if I get 7 years coverage today, it'll be covered for 7 years from today. Want to make sure that is in fact accurate according to what other people have heard.
#32
#33
Download the pdf brochure from the Porsche site given by the URL. It clearly says that there are two levels of protection available.
https://www.porsche.com/usa/accessor...rotectionplan/
In fact, looking over my contract, there are clearly two check boxes and I have Platinum.
Either the dealer and rep are woefully uninformed, or there's another (profit) motive.
#34
Thank you. I guess this raises the question of more time coverage from Fidelity for what I assume is a similar price to the Porsche backed plan, or less time coverage with a Porsche backed plan.
#35
Hey All,
I got the exclusions from the Dealer. If anyone is interested:
Platinum Plan Exclusions – The following items and components are specifically excluded from coverage under the Platinum Plan: standard transmission clutch components, air bags, solar powered devices, hinges, glass, lenses, sealed beams, body parts/panels/body seals, trim, moldings, door handles, all lock cylinders tires, wheels, standard, hybrid and electric batteries, light bulbs, upholstery, paint, bright metal, freeze plugs, heater and radiator hoses, exhaust system, work such as front-end alignment or wheel balancing, safety restraint systems, cellular phones, electronic transmitting devices (except electronic entry systems-remote entry receiver, sender and module, and tire pressure monitoring system and/or sensors), radar detectors, appliances, and vinyl and convertible tops.
It seems like a pretty reasonable list of exclusions, so the coverage seems pretty good.
#36
Hey All,
PLATINUM EXCLUSIONS:
Brake linings, brake drums and rotors, disc brake pads, standard manual transmission clutch friction disc, pressure plate, pilot bearings, throw-out bearing and arm, air bags, solar powered devices, hinges, glass, lenses, sealed beams, body parts and/or panels, weather stripping, trim, moldings, door handles, lock cylinders, tires, wheels, all batteries except Hybrid/EV/Hydrogen High Voltage batteries as listed under Silver Coverage, light bulbs, upholstery, paint, bright metal, freeze plugs, filters, heater and radiator hoses, exhaust system, catalytic converter, shock absorbers, constant velocity joint boots, steering and suspension joint boots, work such as front-end alignment or wheel balancing (except when required in conjunction with a mechanical breakdown), safety restraint systems, audio/security or other system not factory installed, cellular phones, radar detectors, appliances, or vinyl and convertible tops.
#37
I am contemplating getting extended coverage as well, as my 4 years of initial factory warranty will be up in the fall.
Anybody have a link for Fidelity?
Sounds like the Porsche Platinum plan runs in the range of $4.5 - $5.5K for 10 years, meaning 6 more after the initial factory warranty is over.
What does Fidelity run?
#38
For some reason I have never quite been able to comprehend, but which probably had at least something to do with way too much time spent ingesting way too much alcohol and way too much cannabis, I decided my minor should be in risk management and insurance. Utter and complete waste of tuition, except for the times like this when thanks to all those boring lectures I at least now understand how insurance and warranties, extended or otherwise, work. First a highly mathematically specialized team of accountants determines probablilities and costs. Then they go back and forth with marketing, figuring out how to maximize inflated customer expectations of an ingeniously deflated product. Once they settle on the cost of that then they double it, so they can make money, and then double it again, so whoever sells it can make money. I'm talking in general. Sometimes they triple or quadruple instead. Minor variations like that. All based on the assumption the customer is seriously mathlexic. It would seem this scam is so obviously cockeyed and crooked it wouldn't last 5 minutes. Yet not only have these schemes been around since like forever, they continue to proliferate. So maybe there is a lot more truth to that one assumption than we would ever care to admit.
On second thought, considering all the tens of thousands of dollars I've saved buying the least insurance possible when I wasn't avoiding it entirely (and usually only when required by law) maybe those classes weren't such a waste after all.
#39
I am VERY against over-insuring. I always turn down all that extra dealer crap, etc. However, the only reasons I really consider paying for an extended warranty on this 911 is due to PDK issue. Not that I expect any with how low miles I put on the car (though I do drive it quite spiritedly), but that bill is pretty big. Ditto for the engine, though engine issues on these cars are probably the least likely issues that can arise.
#40
I would say PDK is more or less the same reliable as other transmissions, unless there is some known weak spot. Like the 996 IMS bearing that blew up engines.
I had a BMW automatic tranny fail me at 55K miles. Sometimes sh... just happens.
Just trying to figure out if there is a known issue, or if anybody knows of 991 PDK's failing prematurely.
#41
I do find it interesting that Porsche does not have a separate Powertrain warranty whereas most manufactures do. The last time I bought an extended warranty was on my 03 Acura MDX and after the extended warranty expired (usually buy 7/100k) the transmission went and replaced it with radiator for about $5000.
My 911 GTS is not my daily driver and bought pre-owned (still under factory warranty) so I may consider the Powertrain warranty only as the 991.1 3.8 engine should be well sorted.
#42
What is wrong with the PDK's? Any issues for the 991?
