CTEK Porsche Battery Charger ?
#61
AbrahamF:
I'm enclosing a picture to show that if you connect the charger to the underhood boost connector in the Cayenne, it should work. Here is my charger connected...... lights showing that is working.
#63
I normally keep the hood closed if it's going to be charging for a long time. In that case, I just pass the cables through the back side of the hood.
When topping off and I just connected for a couple of ours, I just leave the hood open.
#66
yeah. it should work. after my Porsche branded charger stopped working, I bought similar model, Time-To-Go and it works well with my 991.2 GTS. I also bought the cigarette adapter so it basically works exactly same as Porsche version.
#67
Anyway chargers are certainly cheap enough so as not to break the bank.
Maybe someone else can chime in with more/better info.
#68
Premium Sponsor
The CTEK or any other Chargers have different charging profiles for different battery chemistries. Always best to use the correct charger for the chemistry you have and not mess around. The Lead/Acid is a 6-cell configuration at 12.6v nominal and Lithium is a 4-cell configuration at 13.2v nominal. So some smart chargers send out a pulse that checks resistance and voltage gets that data and charges as it see fit... but its inaccurate if you use the Lead on a Lithium because the chemistries have different voltage and resistance properties. So just use the proper charger for the proper application and you won't have to worry about any issues.
#69
I realize I'm really late to this party but I 100% agree with what Anti-Gravity said. Lithium batteries are charged at a different voltage than lead-acid batteries and that includes AGM batteries. My CTEK 5.0 for AGM and standard flooded cell cost me about $80. The AGM battery in my Cayenne GTS runs around $250 plus a fair amount of labor to get to it if you take to a shop. I would only use the correct charger for my battery. If you no longer need the special Li charger put 'er on eBay to recoup some of your investment and let someone who really needs it benefit from it!
#70
So if someone with a Lithium battery needs a special charger to charge the battery, how does the car's everyday charging system do when it is set up for something like an AGM.
#71
Premium Sponsor
Best regards,
Chad
#72
The difference with a standalone charger for lead/acid compositions(including AGM) is that they have different values for float/maintain as well as desulfation stages which do not properly maintain lithium and can output too much voltage and also possibly over charge.
Best regards,
Chad
Best regards,
Chad
#74
Does the BMS on the 991 have an option for a Lithium battery? I know Porsche has a Lithium battery as an option or maybe even standard on an upper end model.
