Key Not Found (Entry and Drive)
Old 02-03-2018 | 03:50 PM
StormRune's Avatar
StormRune
FYI: In a bind you can always lock/unlock the door using the emergency key embedded in the fob. While on a 997 the slot was visible, in the 991 models you have to lift the door handle and look under it, it is hidden by the handle.
[Edited the above to correct as pointed by Porsche_nuts]
Old 02-03-2018 | 03:59 PM
Porsche_nuts's Avatar
Porsche_nuts
Originally Posted by StormRune
FYI: In a bind you can always lock/unlock the door using the emergency key embedded in the fob. On a 991.1 the slot is visible. In a 991.2 you have to lift the door handle and look under it, it is hidden by the handle.
On .1, the keyhole is hidden and also located underneath the handle
Old 02-03-2018 | 04:03 PM
StormRune's Avatar
StormRune
Oops, I confused it with my 997. Thanks for the correction! I'll touch up the original post as an edit so as not to mislead.
