Has anyone done a CarPlay retrofit / Headunit replacement for 991.1
#526
For those installing the Joyeauto (or any other kit really) in the US, you'll need some longer standoffs than are provided. It's a very tight fit due to the Sirius board and antenna connector.
Overall, you'll need (3x) M2.5 x .45 x 43mm male-to-female standoffs. Since that length isn't readily available, you can order these two part numbers (3 of each) and stack them up as seen below:
1) 31mm: https://www.mcmaster.com/98952A121
2) 12mm: https://www.mcmaster.com/98952A109
I also opted to put a layer of kapton tape over the components to keep them electrically protected should anything conductive find its way into the box or short while putting back together. Not required, but doesn't hurt either
Installed, it should look like this (the ribbon cables get slightly pinched, there's no way around this but it's not a problem):
The following 2 users liked this post by Bry5on:
Jrbreeland (05-16-2021),
Porsche_nuts (06-22-2019)
#528
At first i thought this was a great idea. But seeing how iffy and complicated this all is ( to me anyway) I’ll just continue to use my iphone . I have 30 or so albums loaded in the jukebox anyway. My wife's car has apple play and it is truly great, but not worth the cost and aggravation to attempt for the 911.
#530
#532
Mine is a 2016 and needed M2.5, M3 did not fit as I had ordered those based on this threads guidance.
The kit came with M2.5 standoffs that were less than half the length required.
If you order the part numbers I provided above, you should be covered for all sat radio configurations. If your requirement is shorter than mine (early or mid production car?), don't stack the short ones on top of the long ones and you'll have more clearance for bending the ribbon cables.
#534
If I would have decided to install the rearview cam as well and if they would have whined about its installation as well, I would have been quoted $500 and end up paying $700. I think you have room for further negotiation.
tkkhoo (06-29-2019)
#535
Cman21
tkkhoo (07-04-2019)
#536
I paid $1100 to ACG Automotive, San Diego https://acgautomotive.com/
They took really good care of me and my 991.1 including the whole backup camera install. Considering the entire install takes 8-9 hours, i found that price completely reasonable. Besides ACG was highly recommended by Nick/NM Automotive and as far as i found they are the ONE AND ONLY experienced installer of the system in So Cal. Contact Girard at ACG and he will take excellent care of you.
tkkhoo (07-14-2019)
#537
It's actually not that hard, but the first time it's def intimidating.
#538
I finally got the car back. I am blown away by how well the NM Automotive box works- almost seamless and definitely looks stock. Backup camera works well (though inexplicably sometimes the guidelines don't show when I put the car in reverse). The people I used for the install did a great job- so if anyone in the Midwest/Iowa area is looking for an installer, Fusion Auto Sound in Des Moines is who I used. Initially was quoted $850 but it took them less time than expected so they lowered the price to $765.
