Has anyone done a CarPlay retrofit for 991.1
#331
Playing radio with Waze in background could be problematic as Waze is muted and you cannot hear Waze LEO or hazard alerts. I guess the same applies to Jukebox - if you have Jukebox on, Waze is muted.
#333
#334
#337
I'll disconnect the battery when I do the wiring for the rearview camera but in my opinion, removing the PCM while the battery is connected is very, very low risk.
#338
I agree there is a very low risk when removing the PCM without disconnecting the power source. However, a risk still remains and the best advise to share with those who have very little or no experience is to remove “all” risk by disconnecting the power source. I have been working on electrical components for decades and I was trained to always be safe and not to take risk no matter if you’re an apprentice or journeyman.
#339
#342
Had Sidvicious7 came over and tackled the camera and CarPlay. The process, to me at least, was very challenging, with Sidvicous knowing where and what to remove (he did all the work), still took at least a good 8 hours. But along the way, it was lot of fun exchanging notes about the p-cars. What a great day!! Thanks again Sidvicious7!
OOOOH, NICE 50!
#345
Last week I decided to verify if I can listen to my FM stations and view Waze in the CarPlay mode. I was able to listen to my FM stations while in the CarPlay mode; however, Waze will mute but I was able to read the directions on my PCM display without an issue.
Where do I keep/placed my USB cable. For my vehicle I elected to place the USB cable in my center console. The install for a fellow Rennlister his choice was to run the USB cable out of the passenger’s side panel. You can also run the cable to the glove compartment. Also, I discovered that the OEM USB port in the glove compartment still functions in a capacity for an iPod and will charge the phone (CarPlay mode is not capable unless the installer modifies the port for CarPlay with the proper USB adapter/cable).
I just bought my kit from Nick (android auto version). Everything is installed, just dont know where to put the box. Behind the pcm seems really tight. It does not fit under the HVAC controls. The suggested spot in the drivers footwell also did not seem to work. Anyone have other spots or suggestions/helpful hints?
