Clutch/flywheel replacement in 991.1 GTS
Good time to do a lwfw while you're in there if you want more zing to the engine and don't mind the extra noise at idle and revs to pull away from a stop. If it were me, I'd stick to the oem clutch vs a lighter weight or more aggressive option cause that really starts to impact driveability for me....
Received 5,413 Likes
51,000 miles here. No slippage.
Brake fluid flush also effects hydraulic clutch fluid. So hopefully you were doing your every-2-year brake fluid flush. I feel a very slight difference in my pedal after said flush. FYI.
Replace before you damage the flywheel. The FW adds about another $rand to the invoice.
