Recommendation for a trickle charger
Old Dec 24, 2017 | 08:08 PM
bwiele's Avatar
bwiele
I just got this:
https://www.amazon.com/gp/product/B006G14FK8/ref=oh_aui_detailpage_o02_s01?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B006G14FK8/ref=oh_aui_detailpage_o02_s01?ie=UTF8&psc=1
and these accessories:
https://www.amazon.com/gp/product/B00ADIHUVG/ref=oh_aui_detailpage_o02_s01?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B00ADIHUVG/ref=oh_aui_detailpage_o02_s01?ie=UTF8&psc=1
https://www.amazon.com/gp/product/B0016LA5O8/ref=oh_aui_detailpage_o02_s01?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B0016LA5O8/ref=oh_aui_detailpage_o02_s01?ie=UTF8&psc=1
Connected it in the footwell plug, wire exiting on the underside of the door. Working perfectly. Nice solution at a pretty good discount to the Porsche branded one.
Old Dec 25, 2017 | 06:40 PM
N2B8TOR's Avatar
N2B8TOR
Originally Posted by bwiele
I just got this:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
How do you like it I'm thinking of getting the same. Either the 4.3 or the old 3300 model. But same accessories.
Old Dec 25, 2017 | 07:30 PM
pfbz's Avatar
pfbz
Really hard to beat Deltran Battery Tender's... 10 year warranty, sophisticated charging algorithms, can be left connected to car without risk of overcharging, compact, durable, inexpensive, come with hard-wire harness, etc. They work equally well on 6V, 12V, conventional lead acid, AGM, Gel, and most LifePo4 batteries.
Between five motorcycles, two cars, a truck and battery-start lawn equipment, they get used pretty much constantly and without failure. They also keep the batteries in play for longer than expected.
Specifically, i'd suggest a Battery Tender 3A Power Plus, $46 shipped on Amazon and often on sale at Costco.
Amazon Amazon
Old Dec 25, 2017 | 08:26 PM
DBH's Avatar
DBH
I agree - Battery Tender. Plug it into 12V port in the passenger footwell. Plug the other end into wall socket. Walk away and come back in two months. Cannot get any easier than that.
Old Dec 26, 2017 | 12:18 PM
KM1959's Avatar
KM1959
Originally Posted by Papa Fittig
I use CTEK MUS 4.3. With my 997 which was a DD and occasional use of CTEK the battery lasted 7 years and survived a alternator cable replacement (a well known issue with 997 cars).
I have used two of these on my cars for a couple of years without problem. I picked them up new off of ebay for about $50.
I have seen other chargers that were cheaper - and probably just as good - but Ctek has lots of useful accessories (like cables) that make them easier to use than others.
Old Dec 26, 2017 | 07:02 PM
Valvefloat991's Avatar
Valvefloat991
I've been using the 4-gang Battery Tender for years and agree that it's a good charger. But it will overcharge motorcycle batteries and boil the electrolyte if left connecting for the entire winter.
To avoid this problem, I turn on the battery tender on the first of every winter month and wait for the four connected batteries--2014 BMS S1000R, 1983 Honda CX650 Turbo, 1965 Jaguar E-type, and Honda electric-start generator--to all achieve float mode. This usually takes about a day--never more than two. Then I turn off the Battery Tender until the first of the next month. Since doing this, my battery electrolyte levels have remained at proper levels and the batteries have still survived the winter in good shape.
Old Dec 26, 2017 | 08:53 PM
DBH's Avatar
DBH
I don't have a motorcycle. But I've never had a problem overcharging four cars over 12 years with the same unit.
Old Dec 26, 2017 | 09:13 PM
pfbz's Avatar
pfbz
Never use the ganged charger, but in 15+ years of using Battery Tender's, never had a problem leaving them connected full time to motorcycles... I have four moto's sitting out the winter on them right now. They will stay plugged in until the spring, except perhaps for an occasional ride during a period of nice weather.
Old Dec 27, 2017 | 12:42 PM
Valvefloat991
Perhaps my unti failing, but I did lose a motorcycle battery a couple of years ago due to a loss of electrolyte.
Old May 31, 2020 | 12:28 AM
sr5959's Avatar
sr5959
Reviving this old thread...I just bought a CTEK charger, and it has 3 modes: normal/AGM/RECOND
Could someone tell me which mode I need to use to maintain battery on my 2013 C2 for 2-3 weeks?
I have a feeling it has a non-OEM battery.
Thanks!
Old May 31, 2020 | 08:17 AM
Rich_Jenkins's Avatar
Rich_Jenkins
Thanks!
Do you know the model number of the CTEK (ref the settings, to confirm mode)? Would also need to confirm battery is wet cell or an AGM. Can you post a picture of the top of the battery showing the label?
Old May 31, 2020 | 08:49 AM
Gary JR's Avatar
Gary JR
Not sure why people are paying so much for these simple devices.
https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
Old May 31, 2020 | 09:37 AM
BOPE's Avatar
BOPE
Thanks!
If your battery does not have removable caps it's most likely an AGM battery; most are these days.
Jason
Old May 31, 2020 | 12:38 PM
Antigravity's Avatar
Antigravity
Premium Sponsor
Being blunt, there IS a difference between quality products and cheap stuff, and a Charger is no different. A higher quality Charger offers higher Amps for Charging faster, better charging profiles that do not over-cycle the battery, and are built to last longer, and use higher quality components in the build. Cheap stuff is a basic charging profile that does not accurately measure what type of charging is needed for the battery.
Old May 31, 2020 | 03:02 PM
Gary JR's Avatar
Gary JR
Being blunt, somebody would have to prove to me mine does not do all the same stuff for a lot less.
