Yes...another Ctek charger / lighter question. Help needed
UPDTE: Yes...another Ctek charger / lighter question. Help needed
First off I have read all of the posts on this topic but still can't figure out what's happening with mine.
I have a '15 GTS and I got the Ctek 4.3 charger. I have been running it via the lighter adaptor under the center arm rest as well as the footwell. It has been hit or miss.
Half the time I come back to the car and all the lights are lit all the way to green like it should be. The other half of the time all the lights are out and the Ctek power light is flashing meaning it lost connection to the battery.
It almost seems like sometime the socket is turning off after a period of time but then sometime it works fine. I've checked and I pretty sure it's not any of the connections.
2 days ago I walked by the car and noticed that the lights were off and the power light was flashing so it had lost connection. As soon as I opened the car door.. the socket turned on and the charger started to fire up again on it's own. The next morning when I went to look at it it was as it should be...All the light all the way to green.
I'm trying to figure out why sometimes the socket seems to turn off and others it will stay on. It's totally inconsistent. The same thing seems to happy using the footwell socket.
I know the most of you will say "just hook it up directly to the battery, but I'd really rather get the lighter to work.
I do have a V1 plugged into the OBD port. I'm not sure this has anything to do with it?
Anybody seen this or can help me? I wondering if it is a faulty Ctek?
Thanks!!
Thanks!!
Try connecting the charger directly to the battery to see if the 12V socket is the source of the problem. My Ctek 4.3 is attached to the battery with the terminal adapter and I've never had any issues.
I have noticed when using the passenger footwell 12v port that the charger needs to be turned ON within a few minutes after the ignition is switched off. If not the car appears to shut that port down along with the rest of the car.
What I think happens is that the port detects input and keeps the circuit ON as long as the input remains there .
Although, yesterday all I did was open the car do which powered everything back on and then close the door and it stayed on.
My experience with a Battery Tender using cigarette lighter port is that if I plug it in immediately after turning off ignition, the charger will remain on. If I plug it in hours after ignition is turned off, the charger will turn off after a short while. I never lock the doors when charging.
not sure. Really never payed attention. Been using the CTEK like this for years without problems. Sometimes it sits for up to 4 months. Always starts right up with a full battery indicated. The one cars battery is 5 y.o. and always good
This is all speculation on my part. I have a generic CTEK that I bought when I had a 987. It does not seem to work in my 2014 Cayenne's cigarette lighter plug. Like all comments here, it will turn off after awhile. However, the same generic CTEK works in my 2012.5 991 cigarette lighter plug.
I also bought a slightly used Porsche branded CTEK charger from Ebay. This one works with the Cayenne's cigarette lighter plug. I got a feeling that Porsche added some specific software in the Porsche branded CTEK so that only the branded ones work in the newer cars. Just an opinion.
I actually ALSO have a branded CTEK that's maybe 3 years old. I used it on my 997.2. I'll do some testing and see what happens if I use that one. I'm hoping that plugging it it right after I drive vs. waiting a few hours to do it is what's causing this. For now it's the only logical answer of why it works sometimes and not others.
