Anyone skipping the 10K service?
Looking at the dealer website, it looks like other than the oil change and service interval reset, everything else at the 10K service is just a "visual inspection" (underbody, brake lines, tires). It seems like if I just change the oil myself q5K miles, then I could just skip this and wait until the 20K check , which is a bit more extensive. Or am I being penny wise and pound foolish?
Received 5,388 Likes
Change your own oil, and do the visual inspections. Document your service and save your receipts. Get something like Durametric to reset your service reminder.
If your car is 2 years old, it needs a brake flush.
If there are any software or other updates to your car, you'll miss them. But none are likely to be urgent and you can check to see if there are recalls or TSBs. You should visually check all the same things they do, which usually means having a lift. Given that at 10k you are likely still under warranty, seems like you might want to see how things are progressing at the first checkup time point.
For the 991.2, the first service is free. Do not skip. Also, don't bother with a 5000 mile oil change. Unless you have been tracking the car, it's just not needed anymore.
I did my own 4 year / 40K service. I printed out the official Porsche tech checklist and went through every single item, checking them off as I completed them. I even signed it as the tech who performed the work . Filed it away in my service binder for the future.
People do. Depends on what your goal is with the car, and how you view your stewardship over it.
One thing to remember is that the 10,000-mile intervals have more to do with what consumers want than what engines "want." 3000-mile intervals are excessive in this day and age of oils and metallurgy—but I like oil changes at 5000 miles or every year a lot better than 10,000 miles. I also like an early oil change (500-1500 miles) as or after the engine is broken in. Is that the easy or cheap way? No. Is it necessary? For those who are leasing the car, the minimum might be the best way. For those who might buy it, or did, or just care about the car, the answer might be different.
I won't claim to know what's right for you, but I'll stick to a pre-emptive oil change @ 500-1500 miles followed by changes at 5000-mile intervals. A friend who worked in the motor oil industry and raced a factory 3.0-liter Carrera RSR viewed oil changes before and after every race weekend as "cheap insurance" even just a few years ago. And he would've known...
If you plan to only have the car for a couple years, you can probably in fact skimp on the services and leave issues that might arise because of it to sucker future owners that buy your neglected car unbeknownst...
However if you plan to keep the car for a long time like me, it’s probably best to get some pro eyes (whether dealer or indy) on the car every 10k miles to make sure everything is going well, but change the oil yourself every 5k because it’s really easy.
Only thing that has me thinking twice about doing my own oil services is resetting the oil level—which apparently requires a PIWIS tool. I understand some owners and some shops get around this by measuring whatever they took out and replacing it with the same amount of oil, but this seems a bit imprecise? Gotta love that you have to "set the oil level" now. I thought losing the old-fashioned dipstick was bad...now it sounds like the electronic "dipstick" is variable and set-able. Gotta love "progress."
