Trouble shooting help needed ASAP ...
A year after I got my 2014 C2S the same happened, cold air constantly on and wouldn't shut off. Known problem. Took it to dealer who just replaced the COV or change over valve. There are a bank of these vacuum operated solenoids. Problem solved. Don't think it's a DIYS as they are buried in the engine compartment.
Could always be wrong. But doubt it.
If that doesn't work then here is a link to the online manual's fusebox layout. There are other A/C-related entries in both fuseboxes.
http://www.porscheownersmanuals.com/...gnostic-socket
I'm not pretending to be a mechanic with my meager skills on our very expensive and complicated cars. Just reporting that I had a similar issue that was covered by warranty. It is discussed here and fixed with replacement of the part.
https://rennlist.com/forums/991/8002...n-991-a-2.html
