Leather option confusion
#31
If I may add something to this excellent thread....
I ordered my GTS today. The "Transmission Tunnel in Leather" option is depicted here--pics stolen, then VERY amateurishly highlighted. There is a seam that lines up with the rear end of the luggage net....I thought maybe this option covered the portion forward of the seam. In fact, it's that AND the entire piece all the way back to where the "rear tunnel cover" starts.
This was confirmed directly from Atlanta today during my time at the dealer. Also, this option isn't available until builds after 11/6/17 (dealer config tool had a little clock and warning depicted). So depending on when your allocation start date falls, this may affect your decision. My date allowed me to select this, but I wouldn't have even known to ask the question except for this thread!
I also chose to eliminate the door panel leather (3 tiny pieces mentioned in posts above--really only TWO pieces if you chose LCA!!) thanks to this thread.
Thanks for the heads up!
Why does LCA affect the door panel in leather option? Is the camera and/or warning indicator placed in that little triangle at the top of the door rather than on the side mirror?
#32
The easiest way to see what is what for a lot of the options is to download the 3D configurator and select leather to sample and then add the leather parts one by one and you can see what you get as the parts turn green. Clicking on the close up and then toggling back and forth shows you with and without.
It does not work for all parts because some are not available with LTS, but for most it does and the ones it does not are pretty obvious.
On a normal leather car, I don't think any of them other than the leather package itself are that dramatic. Maybe sport seat plus backs in leather. Otherwise, you are basically replacing smaller plastic parts of the same color with leather covered parts. On an LTS order with a special colored leather they do make a big difference in some cases.
As for the value of changing plastic to leather when you have black leather, I've found that it has a noticeably different visual texture that makes black plastic and black leather easily distinguishable, especially when they're next to each other with options like the instrument surround, steering column, or extended dashboard in leather. And of course many of these leather options include stitching, which adds some visual appeal even if you're not getting deviating stitching and quite a bit more if you are. On the other hand, these leather options get expensive, so the more you can satisfy yourself with black plastic, the better.
#33
That is exactly correct. With LCA, you can't change that little triangle to anything....no leather, CF, Alcan. The indicator lights are there, not in the mirror.
As to the plastic/ leather aspect.....you've pointed out the texture difference when choosing black leather. But if you choose other colors, I do not think there is a corresponding plastic for each leather color. I asked specifically about Agate Grey matching plastic and was told it will be black. (The "Airbag" cover on the door panel for example) . Just more FYI for the thread.
#34
The value proposition of leather certainly goes up if you're using leather colors that don't have a matching plastic color, which I think was the previous poster's point with Leather To Sample (as long as you don't end up having to choose between having plastic and feeling you're going overboard with your chosen leather color aesthetically, I suppose), but my point was merely that even in the "minimal difference" case of black plastic vs black leather, there's still a case to be made for adding leather.
