Fluid loss radiator
So I used to check my radiator after the first year of driving the car. I hate to admit it but I probably haven't checked it in over a year, yeah bad me. I had to add 2 pints. Yeah I went o the dealer and got ripped off by $65 for Porsche antifreeze. So I went for a long ride and the level did not go down. If I had a leak it would be hard to find i think. Is this normal? I drive the car a MY15 TTS pretty easy. Thoughts?
I'm thinking pretty normal,.....for some reason a little bit of coolant seems to disappear on just about any "newer" Porsche I have ever owned. I've always done the usual looking around and can never find a thing. It's always a mystery, but never had anything bad become of it.
The Porsche coolant will be concentrated; you need to dilute it 50/50 with distilled water.
Given the coolant temps modern Porsches (all newer cars really) run (200-230F) when in non-Sport mode I could imagine minor failures that would result in slight loss of coolant over time. But, I'm not sure I would consider them normal. They might be really hard to find too.
If the coolant loss only (or mostly) occurs during engine use, then a small leak won't leave liquid evidence; The coolant will vaporize due to proximity to hot engine bits. It might though, over time, leave dry stains as evidence.
Interesting. Didn't find that with a quick search. Insanity to pay the Porsche tax on H20 though.
In any case then, the main point for the OP is: read the label so that you know what you're putting in the cooling system.
Yes I added the Porsche stuff 50/50 with distilled water. Was at first going to add just distilled water, I just couldn't figure out how much it needed so I went with the 50/50 mix.
I just can't believe I overlooked checking this.
Seems my bobber is always at min level, no matter how much antifreeze mix I put in. Had dealer pressure check my system and they said everything checked out fine. My SA said don't bother checking bobber and don't worry unless you get a MFD message. Mmmmmm.
O'reilly Auto Parts sells the correct fluid if you don't just want to add distilled water.
https://www.oreillyauto.com/detail/p...13/porsche/911
No, i went to the max drove it for an hour and the bobber was still at the max.
I measured the depth from the top of the filler cap it was 3 3/4 inches before hitting fluid. I'll use that measurement it instead of the bobber from now on. When I first bought the car little over 2 years ago, I added Water Wetter.
I got no warning or anything from the car.
