Multifunction retrofit - success!
My story is about retrofitting the new 991.2 MF steering wheel to my 2012.5 991S.
Background: I bought my car CPO and I love the specs on my car. I really liked having the carbon MF wheel match my interior. My 991S is a cab, so the heated wheel is a must. But I hated the shifters (never made sense to me), so I got the Techart Paddle shifters. After spending all the $$ I really wanted to believe that I was going to be happy with those Techart shifters, but truth is - those shifters were flimsy, and also obstructed the dashboard view. They just didn't feel and look right and they weren't from the Porsche factory. So I was excited to see the first 991.2 steering wheel retrofits being posted. Of course, MF was a no go at first.
Then, Rennlist user Yuan Li had posted his retrofit solution...
The perfect steering wheel for my car is actually a Macan steering wheel. So I bought it new with a new airbag. I also bought the retrofit kit from Yuan Li. I actually thought to myself this isn't going to work. Yesterday I did the retrofit. Beginning to finish in exactly two hours. I am experienced in electronic engineering and have a lot of soldering experience which you need if you have a heated wheel. You need to remove an SMD resistor and swap another one out on a tiny circuit board. Throughout working on the new steering wheel, I was very nervous. But after installing the conversion module into the Macan wheel, and finally swapping steering wheels, everything worked just perfectly!!!
It is just amazing to me that it all worked out. I absolutely love the new look - it actually feels like I have a new car. The MF controls are much improved (very precise), the paddles are absolutely perfect. It really is a dream come through for me.
I posted some before / after pictures. Also a video that shows that all buttons work properly, included backlight function, and the steering wheel heat.
A big thank you to Yuan Li - I am glad someone did all the engineering to make this work.
For those interested - I am happy to help out any Rennlist member. Now that I know how to install the conversion kit I could offer this as a service. I am in Connecticut, USA. Just post a message if I can be of any help to you. Happy to answer any questions or get involved in doing the work.
Before:
After:
Video:
I do think my 991.1 SD wheel feels a bit dated in comparison to the newer ones.
Question - I don't care about the multifunction as much as my desire for a heated steering wheel. Can this be easily added?
Also - if you don't mind, what was your total cost?
How much did this upgrade cost you all in? Also, is it easily reversable back to the original steering wheel in case you wanted to resell with original parts in the future?
My hypothesis is that this has more impact to reviews than the software.
Cost to me:
$1,500 steering wheel
$750 airbag
$400 adapter
$2,650 total
Thank you! Cost will probably vary depending on the wheel you get. My expenses are listed above. I bought my steering wheel and airbag from Europe. They were in the original Porsche packaging and had a manufacturing date of May 2017. PM me if you want the seller's contact information.
Very cool project - one I would also take on myself if I needed to. Congrats!
Original with sport style steering wheel car upgrade multifunction steering wheel,need coding the vehicle from sport style wheel to multifunction by PIWIS.Based several retrofit 991.1 to 991.2 wheel projects,no need purchase "multifunction enable code" for 991.1,MF can works.
Coding the car following this:https://gpsadapter.us/blogs/installa...n-coding-guide
Adapter only support switch mode LED indicator N S S+,not support switch S S+ use switch mode dial,works this video
I'd love to do this, but there's so many other mods to do that I don't know if I'd get to this one.
Any clarification on which steering wheels 1) will physically mount and 2) use the LIN 2.0 bus?
I've seen 991.2 wheels, Macan wheels, and Panamera wheels (what years?) mentioned.
1#Macan,958.2Cayenne,991.2(STMV1/STMV1-H adapter kits fits all of this wheel)
2#971 Panamera,new gen Cayenne,(STMV1-971 adapter kits fits all of this wheel)
Those two type of wheels use same LIN BUS version but different protocol data bits defined,different wire harness and socket architecture in wheel.
