Multifunction retrofit - success!
Old 09-21-2017, 09:32 PM
LTP
LTP's Avatar
wow, awesome mods, thanks Rye and Yuan Li for doing this.
Questions with this upgrade,
Can I just add sport/sport plus **** onto my 2013 991.1 Sport Wheel?
I have a aftermarket Pioneer deck as my PCM was just a CDR.
Do I need to have PCM in order for the multifunction wheels to work properly?
I don't mind losing the adjusting volume function, but what about selecting different function on the gauges?
Old 09-21-2017, 10:32 PM
Yuan Li
Yuan Li's Avatar
I think it’s difficult mount “SC switch ****” to 991.1 sport design wheel,and original wheel inside no electronics box can hold the **** communication,so it’s mission impossible.
Multifunction wheel control aftermarket Pioneer deck need this can bus adapter install between CDR CAN BUS and Pioneer remote control,convert steering wheel control CAN Bus protocol to aftermarket box control signal.
http://www.caraudio24.de/Zubehoer/Le...4a0fc441bee239
Old 09-22-2017, 11:13 AM
Dan Nagy
Dan Nagy's Avatar
Received 2,212 Likes on 1,114 Posts
That's a huge upgrade and nicely done. Congrats!
Old 09-22-2017, 11:33 AM
LTP
LTP's Avatar
let me PM you
Old 09-22-2017, 12:36 PM
wsjchoi
wsjchoi's Avatar
Thanks for posting your experience I've been wanting to do this for awhile
Old 04-16-2018, 04:00 AM
Yuan Li
Yuan Li's Avatar
Heat switch with modified resistor is ready,just replace old one,no soldering works needed.
Old 04-16-2018, 08:52 AM
JAM2
JAM2's Avatar
Looks great. Btw, your avatar pic location looks familiar.
Old 04-16-2018, 05:25 PM
RYE
RYE's Avatar
Yes indeed!! I'll have to keep an eye out for your car when driving around.
Old 04-17-2018, 10:50 PM
okla7788
5th Gear
okla7788's Avatar
Subscribed. I was originally interested because of the heat function but the wheel looks fantastic! Thanks for sharing your experience.
Old 10-01-2018, 07:31 PM
thklinge
thklinge's Avatar
Just jumping in to say that a Macan wheel in the 991.1 (mine is a C4 GTS) works great. Only one small niggle, which is that pulling both paddles to get neutral doesn't work.
Old 10-06-2018, 05:32 PM
Yuan Li
Yuan Li's Avatar
If original sport design steering wheel with Sport Chrono Package,didn’t change steering wheel type to multifunction,keep in sport design steering wheel type,I think can keep this feature and multifunction works well,except no MF key setting menu in instrument cluster display menu.
Old 10-06-2018, 05:49 PM
Needsdecaf
Needsdecaf's Avatar
Received 2,528 Likes on 1,575 Posts
What’s the difference between the 991.2 wheel and the Macan wheel? Why use one over the other?
OP, nice job! I’ve been wondering if there was an agate gray wheel to do this retrofit.
Old 10-07-2018, 12:51 PM
vodkag
vodkag's Avatar
I am thinking about doing the same I have a 2012.5 with MF steering wheel as well. Is there any soldering needed if I dont have heated SW?
Also what are you doing with your old steering wheel?
I am interesting in your paddle shifter conversion
Old 10-07-2018, 01:15 PM
RYE
RYE's Avatar
No soldering required. Even if you have a heated steering wheel Li now includes the modified circuit board.
I sold my old steering wheel and airbag on eBay. Just be patient, eventually someone will buy it.
Old 10-07-2018, 01:18 PM
RYE
RYE's Avatar
I could only find a Macan steering wheel in the configuration I wanted. Not sure if there's a difference, to me it looks exactly the same and it's a perfect match with my interior. I couldn't be happier!
Quick Reply: Multifunction retrofit - success!
