Dented sport seat plus seat back
Old 07-30-2017, 05:29 PM
mikex25
mikex25's Avatar
Default Dented sport seat plus seat back
My tint installer dented my sport seat plus seat back. I wanted to see if this was fixable? I read some where the seat must be taken out to replace this piece?
it looks worse than the picture makes it out to be, especially out in the sunlight.
if anyone can chime in I will appreciate it
Old 07-30-2017, 05:34 PM
evilfij
SJW, a Carin' kinda guy
evilfij's Avatar
Recover in leather. :-)
Old 07-30-2017, 05:44 PM
mikex25
mikex25's Avatar
i actually like the look of the hard backs.
Old 07-30-2017, 05:47 PM
Porsche_nuts
Porsche_nuts's Avatar
Received 1,199 Likes on 722 Posts
1. did installer tell you or did you find out yourself and call him out on it?
2. how does an installer dent hard plastic when his tools are a squeegee and film?
3. do not think there is a way to fix it, maybe drill a hole in the dent, fill with body filler, and repaint?
Old 07-30-2017, 06:00 PM
mikex25
mikex25's Avatar
my car is brand new and I only drove it to the installer. Took it home and found the dent, there is a another dent towards the wall of the back seat. It looks as if a long tool was lodge between the seat and wall when bringing the seat back up right. I can live with the dent on the wall since I won't ever see it but the seat back I see it every time I get in the car.
i was hoping a new seat back could be bought and installed.
Old 07-30-2017, 06:04 PM
Porsche_nuts
Probably can be done, talk to you dealer - sure it won't be cheap
Old 07-30-2017, 06:05 PM
mikex25
mikex25's Avatar
I was going to call Monday but wanted to see if anyone on here had the same problem.
Old 07-30-2017, 06:49 PM
4pipes
4pipes's Avatar
Patina, leave it, barely perceptible.
Old 07-30-2017, 06:54 PM
Christian Reyes
Christian Reyes's Avatar
If it's metal, dry ice should do it. Take a hair dryer or heat gun, heat up the area and then put a block of dry ice on it. The dent will pop.
Dents with deep creases will come out but the crease will still be visible.
Old 07-30-2017, 08:27 PM
mikex25
mikex25's Avatar
its actually plastic and I heard about using hot water on bumpers but since this is the interior it's not a viable option.
Old 07-30-2017, 09:50 PM
Christian Reyes
its actually metal and I heard about using hot water on bumpers but since this is the interior it's not a viable option.
No water necessary, the dry ice will do the trick if the area is properly heated before time.
Old 07-30-2017, 10:35 PM
mikex25
mikex25's Avatar
i edited my post it's actually plastic, so not sure it's gonna work.
Old 07-30-2017, 10:47 PM
BradB
BradB's Avatar
I feel your pain. I have the same seats. I would insist on the tint installer to make it right. I doubt the plastic can be fixed. I'd certainly get to the dealer and start going through the shop parts listing and see what it takes to replace the panel(s). Sorry man.
Old 07-30-2017, 11:14 PM
ProReflection
Former Vendor
ProReflection's Avatar
My tint installer dented my sport seat plus seat back. I wanted to see if this was fixable? I read some where the seat must be taken out to replace this piece?if anyone can chime in I will appreciate it
NO9
that piece is the airbag cover, replaceable
Old 07-30-2017, 11:35 PM
OKB
OKB's Avatar
you have to replace the part just be careful , you are playing with a air bag, it will blow up, You should have somebody else do it
Quick Reply: Dented sport seat plus seat back
