Luckiest man alive!
I've never had a bad accident or even a close call like the OP on the street, but I've had my share on the track. When incidents occur where your life is in jeopardy, everything slows down. Although the incident may have only lasted for a few seconds, it seems like an eternity. Maybe this is a coping mechanism developed by man over thousands of years to increase our chance of survival in life and death experiences.
Bottom line is that I expect most everyone will perform beyond their expectations in life threatening incidents.
Bet you will be able to relive the moments in slow motion for a looong period of time... I still remember fine when my rear end passed me on a turn under heavy rain.... and that was more than a decade ago....
Glad you you made it through.
Luckiest man alive? Sure sounds like it. It's tough to walk away from an encounter with a swerving semi.
In addition to giving credit to the Porsche engineers, you may want to consider thanking your guardian angel. Sounds like he's on the job, too.
One of the unfortunate psychological consequences of this is that for the near future (at least), every time a truck comes towards you at high speed, there may be a little voice inside wondering if it's going to stray into your lane again. A few months ago a driver ran a stop sign and smacked the front end of my Lexus. Now every time I approach an intersection, my HR still goes up a few BPM. Annoying.
On a different note, I'd probably also get the alignment checked. A wheel impact that hard I think would likely misalign something.
Sorry to hear, glad you had your attention on the road, not fiddling with your phone!!
This guy was not checking his mirrors either.....
its at 5:52 towards the end, can't get film to start there...sorry
Last edited by Jerrygreene; 07-24-2017 at 10:13 AM. Reason: need to star video later
https://youtu.be/7h0rkMUNp88?t=5m52s
Just playing devil's advocate, but maybe the passing guy should have recognized that the guy that bumped into him could not have seen him. It obviously appears that the driver of the car that crashed is the faster driver/car (since he was prepared to pass 3 cars), but the car that side-swiped him may have had no reason to see or expect the driver of the car that crashed to be where he was since that car was shielded by the second car he passed.
Furthermore, it's usually the responsibility of the passee to stay on line, while it's the obligation of the passer to get around the slower car, even if it means going off line. It looked like the red car was getting onto the proper line to set up for the right-hander coming up. The guy passing him, should have been inside of the red car, to his right, not his left. The passing car ended up trying to pass three cars on the left and took a risk that the last car wouldn't see him. Turned out badly.
Hey just glad thread starter was ok. Amazing that's alll that happened.its getting crazier x the day out there with so many distractions for all us drivers. Drive , leave the phone alone!
UPDATE; I figured out was created the dirt /grime behind each wheel.
- Upon initial delivery of car it was detailed ( not uncommon) however each tires had a excessive amount of tire dressing applied which sprayed the underside when driving from back home post pick-up- All is well.
