Anyone that has aero cup kit remove there rear bumper? I was wondering how to access the top center bolts for bumper when u cant manually lift rear spoiler?
Originally Posted by 991carreradriver
My C2 with the Aero kit only has 2 torx bolts to remove the rear spoiler. Confused?
I was curious about *991*'s question too.
As 911carreradriver points out apparently there are just the two torx bolts under the engine compartment lid. Once those are loose you can pop the wing off... as discussed briefly in this post with some distant photos on 6speedonline: https://www.6speedonline.com/forums/...ml#post3835713
Or don't take off the bumper. I can see doing it either way, each has its own plusses and minuses.
pictures? - you mean the 4x torx screws along the rear edge under the trailing
lip of the wing? - not too mention the screws retaining the tail lights?
Purchased the fabspeed valvetronic exhaust system to add valve control to my non PSE 4S( Cant wait for delivery as they build the system at Fabspeed but thats another story)So I was looking for directions on the rear bumper removal so I would be ready when system is delivered< But I have the Aero Cup so I was wondering if anyone with Aero had removed rear bumper. The problem i see is since there is no manual control to lift rear spoiler how do I remove top bolts #2.4 in Larry Cables instructions and also the tail light bolts look covered as well as Larry pointed out. If anyone has the knowledge it would be appreciated https://rennlist.com/forums/991/9295...stall-gts.html Larry Cables post
remove the wing assembly, you will see the top bumper cover bolts. you will need to disconnect the center brake light plug. Two bolts hold the aerokit cup wing in place.
Reason: correction
