Some 991.2 Turbo S clear bra wrap details
Another question for you... how do you get the bumper to drop in order to remove the front headlights? Is it just a matter of removing all the torx screws on the top, bottom and inside the fenders before it will slide forward? On the 997s and 991.1s you need to remove the headlights and retaining clips behind the headlight before you'll get any movement on the bumper, hence my confusion.
Received 1,268 Likes
No need to remove the bumper to remove the headlights. They unlock from the front truck with the key that's in the same box in the car as the toe hook attachment and then just slide out. I posted a DYI on the GT3 forum a couple of years ago, but many others have posted the same since, so you can search.
I believe that has changed with the 991.2s and they are now secured with 2 10mm bolts at the front of the headlight assembly. I'm curious on the best way to get to them.
LOL, its funny how peeps dont listen. He clearly stated how 991.2 sucked because...........
