20x12" Rims - what tires are being run?
I'm running 305x30R20" MPS4 on the rear with 12" rims. Absolutely no problems!
Superman9905 (01-31-2022)
I have been running 265/35/20 325/30/20 MSC2 on stock rims for about 1 1/2 yrs on and off the track, absolutely no issues,well a little inner liner rubbing on lock to lock turn, and I am lowered too.
i have a 991.1 turbo s with centerlock in Stock size
asume it is 11,5 in the rear. Do you run 325 on 11,5 with no issue??
/Palle
Last I checked, there was not a fitment for the N-spec tires in 325/30R20, just the M0. If you find them, and the diameter is the same as the M0 spec, go for it, but the Mercedes tires fit great on the 11.5" wheels.
