Turbo drone noise
I suspect the sound imposer is involved, but how much won't be known until it's disconnected. I did hear of a member a while back that disconnected it and commented there had been some kind of improvement. I recall he had fitted some brand of exhaust on as well so disconnecting the symposer aided in removing some of the drone.
Received 1,553 Likes
As promised, this morning I turned off the Burmester and tried - really tried - to hear a drone.
I could get technical about the definition of 'drone' and go on for multiple paragraphs but I won't.
I don't hear a drone. Up to about 35 mph in all reasonable gears for that speed with RPMs below 3k, what I hear is mostly engine noise as filtered through the cabin and symposer.
After 35 mph tire noise begins to dominate sound in the cabin. I do notice that the tire noise is about double of what it was when new. I attribute this to the POS Pirellis getting to <50% thread depth and anticipate a non-linear increase in tire noise from now until I get Michelins. My experience has been that Pirellis get ridiculously-noisy once below 50% new tread depth.
My conclusion: Either the drone is a Turbo-S-only feature or you all are hearing tire noise.
If you don't hear drone that's fine. I will say that in normal mode the drone is always less mainly because the g/box reaches for a taller gear keeping the revs outside of the range, along with the tune setting of the engine. You will also find in normal the popping on decel is more or less inaudible.
Sports mode changes the tune/pitch of the turbos and more drone is heard in that mode when you are riding the throttle on an uphill incline.
It comes down to the definition of 'drone' and whether or not one finds the sound - regardless of definition - annoying.
The TT is more quiet than every other 'fun' car we own; perhaps my threshold for 'annoying' is vastly different.
While the TT may - in stock form - not provide the 'exhaust noise fix' for most, it is still way better in terms of sound that 99% of other cars the engines of which sound like tortured hamsters or nothing at all.
I still think the 'annoying sound' factor reported above is tires.
Worf try the PSC 2's - heaps quieter than the Pirelli's....better all round esp when you get some heat into them. Agree those Pirelli's are as noisy as hell once they wear past 4/5000kms.
I will probably run the rest of the OE tread off this season and end-up with about 10k-miles on the Pirellis. In the spring it will be time for a change-up to PSS. Since I DD my TT PSCs are a waste.
Michelin rulz. Pirelli drools. And with the latest F1 tire BS my opinion of Pirelli is lower still.
There is some resonance at that speed in 7th, but I just go to 6th or drive faster!
I just took European Delivery of a 2017 911 TTS Cab, did 2,500Km in one week and can assure there is NO drone in this car, now waiting for it to arrive in Canada. I'm very Drone sensitive as I have it bad in my 2013 Viper, changed the exhaust twice and it still annoys me. Had 2 exhaust change on a 08 Viper and had it bad also on a '06 SRT8 Jeep where I went through 4 exhaust changes to get it right.
2017 is def quieter than .1. They have knocked out the popping in SP too. I guess backfiring isn't desirable for the long term health of those expensive VTG's.. Again not to worry - nothing a well sorted system can't fix where the lame sound is concerned. That would be the first thing I would/and will do.
You'd be surprised. The MPSC 2 are pretty damn good in the wet. Nothing at all like the last MPSC version. Now they were a track only tire. I think you will find most using PSS now gone to MPSC 2 won't be going back. I dd mine and the MPSC 2 is very good on street. May need a bit more warming up tho if you want to get aggressive in the corners....and then they really stick. Quieter than PSS and stickier yet still handle well in the wet..
Not to get this thread too far off topic, but my concern with MPSC 2s are not their wet handling so much as how they handle colder temps. No doubt I'm giving up dry, warm grip, but I have less worries with PSS about poking through traffic on a cold day, which doesn't put much heat into the tires, and then wanting to take on that freeway on ramp.
Detailed review coming...
Sounds good and genuinely look forward to your review on that Coldilst. Im sure it sounds fine but you know I've got my doubts on that set up...sorry.....and no offence to sambo as Im sure he means well but I can't overlook the science. Seen this thread at all?
http://www.6speedonline.com/forums/9...pressions.html
For that X to turn blue like that means there is a ton of heat build up/restriction going on there. Take a peek at the cats on the car. See how dark yellow tan they've also become? The mufflers won't show it because the material inside is insulating them. I mean how can they excuse that blue? That is one serious design flaw... Not saying to put a pipe on like in that last shot although it would flow better. Just wondering why they don't fix that nasty restriction. Looks like the whole product needs to go back to the drawing board... You really don't want anything turning blue if you can avoid it.
Take a peek at the heat chart. http://www.bssa.org.uk/topics.php?article=140...sorry that other link wasn't working..
