Blue Porsche 991 Turbo S Gets BBi Autosport Stage 2 Power Package
Basic Sponsor
Attachment 1344394
![](https://c2.staticflickr.com/2/1481/24405023562_5186e494a7_h.jpg)
(Click on images for higher resolution)
![](https://c2.staticflickr.com/2/1549/24145553299_e77de03bc0_h.jpg)
To make this Porsche 991 Turbo S a faster car than it already is, we will be installing our BBi Autosport Stage 2 Power Package this week. The package includes of our Barcode Exhaust System, IPD Plenum & Y-Pipe, Cobb Tuning Access Port. Here are some detailed pictures of the build process and upgraded parts that we would like to share below. Stay tuned for updates and a quick video!!!
BBi Autosport Stage 2 Power Package Includes:
![](https://c2.staticflickr.com/2/1607/24487118916_f648ecca16_h.jpg)
Cobb Tuning Porsche 991 Turbo Accessport V3
![](http://media.cobbtuning.com/catalog/products/accessport_v3_extra_01.jpg)
Features
• Power Gains: Stage 1 increases power throughout the low and mid-range with maximum gains of around 60 whp are seen between 3000-4000 RPM. Low-end torque is increased by over 100 ft./lbs! Stage 2 gains 120 ft./lbs down low and nearly 100 hp. at peak.
• Simple Installation: Everything is included for the simple installation you can do in your driveway! Intuitive on-screen instructions identify your exact vehicle, saves stock vehicle data, and displays available OTS maps.
• Change Maps: Store up to 100 maps from our OTS map database or from your favorite COBB tuner and quickly switch between them for any need.
• Vehicle Upgrade Support: As you continue to modify your car, Accessport maps can be used to optimize performance upgrades. Changing the map can be done in less than 1 minute in your driveway.
• In Car Mount: The Accessport can be mounted in vehicle to allow you to monitor the performance data.
• Data Logging: Record multiple data channels simultaneously for in-depth evaluation of engine performance. Stores up to 1 hour of continuous data.
• Gauges: Use your Accessport as a gauge to monitor boost or any other live information, directly from the ECU.
• Trouble Codes: Read engine trouble codes to diagnose issues. Clear them when resolved. Prevent expensive trips to the dealership.
• Full Uninstall: Using the Uninstall option will completely remove our programming from the car’s ECU. It is then able to be re-installed after a dealer visit or on another vehicle.
BBi Porsche 991 Turbo Barcode Exhaust
![](https://c2.staticflickr.com/6/5656/21069832940_a273bd5184_h.jpg)
Features:
• Produces more aggressive exhaust sound
• Reduces restriction to increase horsepower, torque, and improve throttle response
• 304 stainless steel aerospace tubing
• 3" diameter piping throughout system
• Meticulously TIG welded
• Brushed stainless finish
• Significant weight savings
• HJS OBD2 compliant 200 cell catalytic converters
• No CEL (Check Engine Light)
• Direct bolt on replacement
• Stylish design with laser etched BBi logo
• Optional high temperature black ceramic coatings available
• Handcrafted in the USA
• For off-road use only
IPD Porsche 991 Turbo /S Plenum
![](https://c2.staticflickr.com/6/5753/20460914663_b6dc3d82e0_h.jpg)
IPD 991 Turbo /S High Flow Y Pipe
![](https://c2.staticflickr.com/6/5778/20298093334_3bf3b28c5d_h.jpg)
IPD 991 Turbo Plenum & Y-Pipe Features:
• Increases horsepower, torque, and boost responsibly optimizing air flow efficiency
• Designed with 3D Modeling & Computational Fluid Dynamics software
• Utilizes diversion splitter and dimpled interior surface eliminate turbulence and increase air flow
• High quality cast aluminum construction
• Direct fit OEM replacement
• Made in USA
Features
Features:
• Made in USA
![](https://rennlist.com/forums/signaturepics/sigpic165623_1.gif)
Bringing Passion, Artistry, Craft to the Porsche Tuning Industry
Southern California's Porsche Performance Tuning, Engine Development,
ECU Software Tuning, Custom Fabrication, Race Preparation & Factory Service Center
Website: www.bbiautosport.com Email: sales@bbiautosport.com Phone: (714) 843-0200
Follow Us On: Facebook & Instagram
Basic Sponsor
George, here are the prices for the components individually:
Cobb Tuning Porsche 991 Turbo Accessport V3 $2395.00
IPD 991 Turbo /S Intake Plenum 74mm $950.00
IPD 991 Turbo /S High Flow Y Pipe $1295.00
BBi Autosport Porsche 991 Turbo Exhaust System $5200.00
Basic Sponsor
While both are great platforms, the Cobb Accessport offers unique capabilities such as the ability to quickly load files and return to full stock mapping (without the assistance of a shop), has data logging capabilities, view and clear trouble codes, live view of digital gauges, and being open sourced to have custom tunes.
- Jerry@BBiAutosport.com
Basic Sponsor
First, we replace the factory restrictive OEM plenum and y-pipe with the improved IPD system.
![](https://c2.staticflickr.com/2/1493/24113356663_139ad1ba4a_h.jpg)
IPD Plenum & Y-Pipe Package Mock Up & Dissected View
![](https://c2.staticflickr.com/6/5783/21803551562_bcc4589300_h.jpg)
![](https://c2.staticflickr.com/6/5735/21192614984_dff89e92ac_h.jpg)
![](https://c1.staticflickr.com/1/625/21194261573_5d091dfa9c_h.jpg)
![](https://c1.staticflickr.com/1/587/21627305610_8afa875f1e_h.jpg)
IPD Plenum Installed on Vehicle
![](https://c2.staticflickr.com/2/1719/24407642422_ca15b0e082_h.jpg)
Throttle Body Installed
![](https://c2.staticflickr.com/2/1634/23887740844_9ecc37477d_h.jpg)
Next, we install the IPD Y-Pipe
![](https://c2.staticflickr.com/2/1491/24433564421_2a9650e72b_h.jpg)
![](https://c2.staticflickr.com/2/1613/24489734536_ff94d9e216_h.jpg)
![](https://c2.staticflickr.com/2/1710/23889122593_6a80a96359_h.jpg)
Would love to hear how it sounds like...
Basic Sponsor
