5 Point Harness
5 Point Harness
I'm writing to see if anyone has had a 5 point harness installed in their 991 Turbo without too much hassle or customization? I've tracked my 2014 Turbo S several times now and am carrying more speed that I probably should without some safety equiptment. A couple of weekends ago I kept having to tighten my seatbelt. IF so please share your experience and knowledge.
Can't do 5 or 6 pt. harness without race seats and a semi roll bar or Brey Kraus harness bar. But it can be done.
Have you tried locking the shoulder strap with the seatback set back, and then powering the seatback forward forcing the shoulder strap to lock with more force? This will lock the seatbelt quite tight!
Thanks. I'll reach out to the Brey-Krause guys. I'll also try the seat belt tightening trick. I did realize, a little late, that I did not fully pinch my seat to help.
Rob
Rob
This winter I am going to yank out the standard seats and install a pair of Cobra Misano 30th Anniversary seats with optional sub strap pass through, and a Cantrell Motorsports half cage and Schroth belts. The Cobra seats can be custom ordered without the tacky logo, and they are sport seats so I can still have a comfortable driving position on both road and track. They are also the nicest looking seats I've seen. Total budget, $9000 for custom seats, half cage, and belts.
Note: They do offer this seat with the sub-strap pass through, and you can customize the fabrics (Alcantera or leather) and add custom graphics or just remove their logo.
I fell down that slope on my GT3. Took a perfectly good, semi-streetable (all stock GT3's are semi-streetable) GT3 and MANY $$$ later, turned it into a DE track monster.... But removed all the fun from driving it on the street, which is one of the reasons I'm now in a stock TT and loving it!!
It's a very slippery slope, use caution! LOL
(BTW - I notice the Radical, so...you have the best of both worlds now)
LOL... OK, if you want to make your TT no fun on the street, here's the list of GT3 mods that turned my car into great DE weapon... but a crappy DD:
1. GT2 rear sway bar
2. GT2 rear brake duct kit.
3. GT3 Cup shift cables
4. 2005 996 GT3 Cup transmission (from Jim Hoddinott's Cup car)
5. Porsche RS lightweight clutch and flywheel
6. Porsche light weight RS crank pulley
7. Sharkwerks muffler by-pass
8. Sharkwerks lightweight tips
9. Cargraphic radiator screen kit
10. Giro-Disc floating front rotors
11. Pagid RS29 pads
12. WEVO semi solid enigine mounts
13. RSS 930 series 4 pt Hybrid roll bar
14. OMP WRC seats
15. Schroth Profi-II Hans 6 pt harness
16. Rennline wheel stud conversion kit
17. Rennline pedals.
18. RSS adjustable upper rear link kit
19. RSS Tarmac Series lower control arms
20. RSS Toe steer kit, front and rear
21. RSS Thrust Arm bushing kit
22. Intrax 4 way adjustable coil-over suspension custom tuned for GT3/RS.
23. O.Z. light-weight track wheels with Hoosier R6 tires (3 heat cycles + new set)
24. Victor track wheels with Hoosier rain slicks
25. Lowered, corner balanced and aggressively tuned to GT3 Cup Car suspension specs.
Word of advice..... don't do it!
OK - you fell off the slope and tumbled violently all the way to the bottom
