911 Turbo S Engine Auto Stop and Start
I've had my 2014 911 Turbo S for just two weeks as of today and was wondering does anyone really use the engine Auto stop and start feature on this car. I recently just turned it on to see what it does and if appears to work as stated. When the car come to a stop it will shut down the engine as long as your foot is on the break, and if you're driving along and take your foot off the gas the car would just coast and the RPM drop to idle speed. That feature I really like but the stopping and starting the engine I feel a little uneasy about. In time isn't this going to affect the engine starter?? In traffic this is happening a lot and I don't want this to hurt the starter in the long run. Should I be using this, or maybe turn it off in heavy traffic???
2014 911 Turbo S
This car is a BEAST
2014 911 Turbo S
This car is a BEAST
No doubt that using this feature will cause more wear on starter components. But will it wear out the starter before you sell the car? Who knows. As for heavy traffic, that's the time it is most annoying because of the higher frequency of starts. But spending a lot of time stopped and going nowhere is where the system can best do its job and save fuel and reduce emissions. Whether you favor saving on the or saving your starter is up to you. I've tried the feature a few times when I have high waiting times during commutes or other mundane things. Also, you probably notice it doesn't work until the car is warmed up.
Thanks for your feedback, and yes I'm aware that the car needs to warm up before that feature would start working. I'm worried more so cause I hope to keep this car for a long time so if using this is going to lead to issues with the starter down the road I don't want to use it. But considering they have this feature in the car did they beet up the starter to handle this over the long term???
What many dealers do on this car before it is even sold is reset the switch default to off, so if you want it on you will need to manually activate it by pressing the button. Just ask your dealer and he will reset it using the piwis. It is no big deal to do, takes little time to change. I agree the stop start feature has value in high idling traffic situations but I personally wouldn't advise using it if you are travelling at any speed and then come to as stop as the engine shuts off as you know and the turbos would be still spinning at a higher rpm. The wear to the starter would be my least worry.
I agree that it can be annoying in stop and go traffic, and I will turn it off then. Otherwise, I leave it on. The people that made a clutch and transmission good for endless launch control launches can surely engineer a starter motor that's up to its intended duty cycle.
Its a Porsche, not a Chevy - trust in the engineering.
Good point, well I've been leaving it on so far and lucky haven't run into really heavy traffic yet. I really like the coast feature when this is on, and for the user who said the engine would turn off before the car comes to a full stop doesn't really understand the features of the Auto engine shutdown. Only when the car comes to a full stop does it shut down the engine. With that in mine the Turbo is not spinning at the point.
Like you, I like the coast feature, although it takes some getting used to the weird feeling when you come off the gas and you don't get that engine-drag-braking feel.
Actually, I too have found that when braking to a stop, the engine will shut off just a little before the car is completely stopped.
I'm pushing almost 14,000 miles on my 2015 TTS. I use auto-stop/start all of the time unless I am in traffic creeping along. I completely trust the engineering. It seems absurd that just a decade ago we had to run turbocharged engines through a cool down period to ensure the bearings didn't get cooked. Now the DME instantly shuts off the engine below 4 mph provided the brake pedal is pressed. Electrical cooling systems help, but I'm not sure how the oil is effectively cooled during shut downs. The 918 has a similar feature as a hybid with an on-demand internal combustion engine. Is it worth the 4-8% fuel savings? No, but Porsche has to meet stringent emissions standards and this is one trick in its arsenal.
Everyone who has driven with me hates the feature! They feel vulnerable as if they may have to get out and push-start the car.
Personally, if you like it use it, and if not then have it programmed off. This would not void your warranty.
