PCCB Front ROTORS Repalacement ??
#31
Ceramics don't fade at the track and if they aren't allowed to overheat, the rotors will not oxidize which is the main source of degredation since the pads are what take the wear. As I said, I just changed my pads and they had 80% wear left on them but they crystallized from the heat and were making a rasping sound so it seemed better to replace them than risk damaging the rotors. If you let your pads run below 50% then you risk damaging your rotors. Clearly $700 for a pad replacement job is a lot cheaper than $12-$14,00 to get the front rotors replaced.
The other issue that my shop is planning to look into is cooling. If there is an enhanced cooling solution then it's worth it for cars that are going to be tracked very much as again, it's the heat that can cause oxidation of the rotors and that is what degrades them. Heat has to be over 1500F in order for the oxidation to begin and so a hard track day could do this. Maybe that is why Karl's rotors look the way they do, after all, he has 25 track days and he still hasn't told us how many sets of pads he has gone through.
Brake fade is dangerous and I for one would prefer to be safer at the track as I am nothing more than an amateur out to have fun and stay safe. If it costs more to be safer then I see no reason to scrimp. Ceramics don't fade but steel does and brake failure causes crashes. Just recently had a Corvette crash at turn 12 after the long straight. The driver got out alive but his car was destroyed and it was due to brake failure.
#32
Received 1,682 Likes
How many track days do you get out of 20% of a set of pads?
#33
Two. However, the second day it was 100 degrees outside in September and it got very hot in the afternoon. The first day was in July but it only got to 95 but it was still hot. Keep in mind that is actually 40% since you aren't supposed to get below 50% anyway. They were 80% when I started the second day, probably less by the time I was done.
#34
Either way, and costs aside, I wouldn't swap my ceramics for steels any day of the week. The benefits are just too good.
#35
Ok. Assuming you are observant and dilligent about pad changes so as to not prematurely wear the rotors how may track days do you think you can get out of the rotors (and what supporting data do you have?)
Also, do you have data on the wear rate difference front to rear or is it the typical 2:1 F:R ratio.
I'm interested in doing the math.
#36
#37
Are PCCB's worth it? Absolutely if you track your car. Porsche grey iron rotors are excellent brakes and so far I have not seen any recent 991's have trouble with overheating on track with them. This is not the case with grey iron rotors on all cars, however. Maybe the lower unsprung weight makes little difference to amateurs in lap times, but the PCCB's are optimal for the 991 in lower weight and braking performance.
#38
Former Vendor
Iron Conversion:
http://www.racingbrake.com/RB-Iron-R...por-irk-03.htm
PCCB Replacement:
http://www.racingbrake.com/RB-CCM-Re...por-crk-01.htm
pccb discs are made by Surface Transforms.
Learn how these discs are made...
http://www.surfacetransforms.com/cp5.php
PCCB Replacement:
