PCCB Front ROTORS Repalacement ??
Dealer say i need to replace front PCCB rotors!
I need opinions please??
Attachment 980861
Attachment 980862
Attachment 980861
Attachment 980862
Received 1,543 Likes
Crap. If those were steel I doubt they'd pass tech.
Originally Posted by Karl911
30K miles , 25+ track days!
Dealer does not have density measuring device!
No Carboteq measurement?
Would definitely need to know rotor carbon state before replacement.
Just got back from Champion Motorsports.
Here is the story. Champion Porsche (dealer)had a density tester, they told me to make any appointment for Wednesday, quoted me $350. i then called Champion motorsportst told them to borrow the tester from their parent service department. So, they got the tester when I showed up.
Tester was brand new in the box never used. Mechanic read the directions, and it was really very simple to use. Three mark numbers on hub, all numbers were below allowable limits.
Basically they are TOAST!
Have 30 k miles on car 25+ track days, i have no clue to how many track miles?
Anybody have experience with Race Brake in Fullerton ,CA??
The edges look damaged, did someone tell you that was from usage? Is this really what normal wear looks like?
When you say 25 track days, is this 4-6 20m sessions, or longer each day?
When you are on the track, do you do 140+ then brake down to 70 each lap, or is this lighter usage?
I see a lot of people at track days pushing their top speed each lap on the main straight, I have never seen the point in doing this, you are just goin to burn off the speed using your brakes at the first turn. I have more fun in the turns, who cares about you max speed....
