Price difference between Turbo & S Model's with same option's!
#61
Speed21
Can we see some pictures of your Porsche TT(s) or specs of your car(s)?
These forums are for enthusiast to express and share their experiences.
Rennlist members have garage queens to track kings, each to own lifestyle.
Please respect other members.
PS: I see you got throw off 6speed!
Let me be a little more direct; you'd likely be the last one I'd take it to, should there ever be a failure...
I'd probably get an accurate diagnosis faster than you, on my own.
By the way, exactly what do you drive? I've seen a lot of your posts and quite a few posters who don't really think much of you or your posts, but have never actually seen or heard anything about the Porsche you own? Do you? Do you have any pictures of it?
You seem to thrive on contention, judging by most of the posts I have seen of yours around here...seems that you always have to be right, so is that generally what you do on forums? Is there some deficiency you feel you need to make up for?
A sad little man sitting alone at a keyboard is the only image he conveys. No more, no less.... always!
In my case a TTS cab vs the TT cab with options "I wanted" had a $30K delta.
$30K buys a lot of gas, tires and an exhaust... Plus perhaps a tune down the road!
#62
back to OP's question
Bottom line to this thread is you can pay more to option up a base turbo in a bid to match the output of turbo S but it will never be the same sum of its parts as a total car. Tuning the base engine just throws everything out, along with the warranty which is incinerated immediately. Doesn't make a lot of sense to me when you cant even effectively use what you've got. But by all means to each their own!
My point is simply that until I can drive my TTS on a circuit at 10/10, my stock car is more than enough for me. If and when I get there, my choice will probably to get the next version of the 911 turbo or maybe the one after that, which will be making a lot more power than the 991.1 or 991.2 TTS. My comment about Z06's relates to my first hand experience at the track recently. They are amazing cars, but do not have the reliability of a Porsche, at least not yet.
#63
Actually given the similarity between the 997.2 TTS and 991 TTS powertrains the 997.2 TTS experience has been very instructive. Bigger ICs and a revised tuned from GIAC did the same for the 997.2 that they will for the 991 TTS -- a huge jump in performance that plunged quarter mile times into the nines. I am just not hearing reports of the GIAC tune blowing up 997.2 TTS engines and those tunes have been out for many years already.
Upgraded intercoolers are a common option when turning up the turbo boost with a big tune. With my other car, the 2015 E63 S, all the major tuners have them available (Renntech, AMS, Weistec, etc). Dinan has them for many of BMW models it tunes as well.
And at the time I bought the GIAC Stage 2 tune I was well aware that Champion was developing bigger Intercoolers for the car just as it had done for the 997.2 Turbo and Turbo S with success.
I don't believe GIAC has simply relied upon the car's safety measures to protect the car against the extra stress from its tunes. The tune itself, according to them, has built in safety measures.
If GIAC's tune was killing our cars' motors it would be all over the modding scene and this forum. But it isn't.
The 991 TTS is plenty fast in stock form. But some of us want more power and are willing to take whatever risks may result. But I don't see the risks as major
sdg1871, reading over your posts regarding your heat soak issues, I note others with similar mods/tune are not experiencing what you are. Im not saying the IC's are completely innocent here but you dont want to be in a position of bandaiding the problem. Have you ever given any consideration toward going back over the basics? Far too often people look at the bigger things as being responsible rather than the little things. I see you have a BMC, IPD, GIAC and the EP exhaust. I would suggest that you go through a process of elimination first, such as removing the BMC and checking/cleaning all the sensors. These filters are reknown for contaminating the sensors and really have a questionable performance benefit period. Personally I would not use an oil reliant filter given the fact you have poor access to cleaning and checking, along with the position of the engine in relativity to the debris that trails the cars slipstream. Do your checks there and see what you find. If all is perfectly clear, then i would then look at the install of the ipd and exhaust. You may even need to remove the exhaust to visually check the cats for blockage or damage. If the car has been running rich anything is possible. Anyway feel free to pm me and if I can help at all Im happy to do so. Also be mindful that Porsche has kept clear of using any metal based products in the intake ducting and plenum area, another potential, putting aside the fact the IPD plenum is disturbing the balance of the evap systems. I note CMS is producing carbon fiber ducting which may be worthy of consideration in future. Now if only they could mold the plenum using the same material...and fit the stock valving using factory positioning. GL.
#64
"Never argue with stupid people, they will drag you down to their level and then beat you with experience.”
-- Mark Twain
#65
#66
Yup for the 991 Works1 Package Installation right?
There is no confusion for me. Just wondering how this thread went this far off topic?
#68
The OP might be getting confused with a lot of discussion about modifying a base Turbo vs the extra cost of a TTS and may, after all decide to get a base and tune/modify it. I certainly respect anyone's prerogative to tune their car. I am happy to learn that so far no tuned car has overheated or gone into limp mode, except for repeated drag runs on hot days. Go for the iron rotors as well, just keep in mind that changes of pads at 50% extends the PCCB rotor life significantly.
2. I'm with you here Andrew. And re .2, it's a direction I will be likely taking as well. They don't make em worse!
#69
No Ragrets getting base turbo
I wanted a 911 turbo but had a nice 991 optioned perfectly so had a hard time justifying the $100k difference. Then I was offered a big discount on a '15 turbo so I ordered it the way I wanted it (probably the only base turbo around with PCCB's). I didn't want PDCC and had a bad experience with CL wheels on a Carrera GTS. Besides, I like the looks of the 5 lug turbo wheels. I know the resale value will be better on the TTS but I saved so much and got all the car I want for about $160. I love the car, the torque and don't miss the extra of the TTS. I look for excuses to drive anywhere. We are truly fortunate to be able to drive such an amazing car and to be able to order it exactly how we want.
