Sponsored by: Road Spy
Removing the rear horizontal and vertical fins from the decklid
Old Mar 17, 2026 | 08:12 PM
UH2's Avatar
UH2
Question Removing the rear horizontal and vertical fins from the decklid
2019 991.2 Turbo S: Does anyone know how to remove the fins from the deck? Hopefully with pictures?
I can remove the whole deck, but I can't figure out how to remove the fins without breaking something. I'm replacing the fins with carbon bits, and I'll pay someone if I HAVE TO...but it seems like I'm already halfway there.
Old Mar 17, 2026 | 08:45 PM
HRJ's Avatar
HRJ
I did it on mine. Broke every one of the stock ones that came out. So, essentially I’m no help lol
File Type: jpeg
Old Mar 17, 2026 | 09:32 PM
UH2's Avatar
UH2
Oops! LOL
Old Mar 18, 2026 | 09:54 PM
HeyNowSkippy's Avatar
HeyNowSkippy
I'm curious as well. I want to detail around the fin/decklid interface, and I'll have the best results if I can remove the vertical slats.
Old Mar 24, 2026 | 04:58 PM
BsktCase911's Avatar
BsktCase911
So from what I know having done mine on a 991.1 Turbo S, it should be similar to the .2. That inner panel that has the vents and fins on it is removable via 4 (or 6) Torx screws hidden in the decklid cavity. You'll have to look inside the openings of the underside of the decklid and find them. Once you remove those, the panel also probably some tabs that snap into place. You can find those as well underneath and gently pry them out. Once that whole panel comes out, you'll see the clips that hold the slats and fins on the underside. Removing those without damaging them is tedious but if you take your time, you'll be fine.
Old Mar 25, 2026 | 06:00 PM
HRJ's Avatar
HRJ
That’s how I did mine. Except for the part where the OG parts came out fine lmao
Old Mar 25, 2026 | 06:24 PM
UH2's Avatar
UH2
I might just tap out and pay someone to do it. I didn't see a second set of torx screws, but knowing that they're hidden would explain it.
Old Mar 25, 2026 | 06:43 PM
BsktCase911
I’ll check the parts diagram when I get home and see if what I have includes the .2 models. Might also be able to search online for the exploded view parts diagram, which should show the screw locations.
Old Mar 25, 2026 | 06:51 PM
BsktCase911
this might be helpful
https://www.eurospares.com/Porsche/9...ille-d-mj-2017
Old Mar 25, 2026 | 07:06 PM
UH2's Avatar
UH2
Originally Posted by BsktCase911
Ohhh thanks! I might just make this a weekend job her in a few days.
Old Mar 26, 2026 | 11:17 AM
abiazis's Avatar
abiazis
Prices to replace the air guide with carbo fiber over $10K.......wow...
Old Mar 29, 2026 | 01:09 AM
UH2's Avatar
UH2
On second thought...it doesn't really show me anything on the fins/louvers and how they attach. I can already get the whole deck lid assembly off.
Maybe I'll give it a shot tomorrow and take the lid out into the sun and study it.
Old Mar 29, 2026 | 02:10 PM
BsktCase911
Yeah I noticed that too. The louvers on the .1's are just snapped into place with plastic clips. I have to imagine the .2's are the same way. You should be able to see those once you get that insert panel off.
Old Mar 29, 2026 | 03:17 PM
UH2's Avatar
UH2
I just pulled the lid off. I don't see any hidden screws.
Old Mar 29, 2026 | 03:21 PM
UH2's Avatar
UH2
I think I might have figured it out. No screws..it might be clips that you have to squeeze and push.
I'll report back after I've broken all the plastic.
