Sponsored by: Road Spy
Active aero pump
Old Apr 12, 2025 | 07:14 PM
E Allen's Avatar
E Allen
Default Active aero pump
Does anyone have a good working pump for the front active aero that want to sell? Mine has been popping a fuse and I'm pretty sure its just a pump but not 100%.
Old Apr 13, 2025 | 09:21 PM
E Allen's Avatar
E Allen
I ended up buying a new control unit so delete. Thanks
Old Apr 14, 2025 | 09:59 AM
RSBro's Avatar
RSBro
Seems like all of our .1 and .2 Aero pieces are failing at the same time, here recently. Gives a good indication to their useful lives. I get mine back today/tomo, they replaced a sensor or something for my front lip/bladder, I'll find out exactly what part # it is when I get the 'bill' back, thankfully it's still under CPO...
Old Apr 14, 2025 | 07:55 PM
E Allen's Avatar
E Allen
I'd love to start looking at alternative fixed front lips that don't hang to low so I can delete this finicky system.
Old Apr 15, 2025 | 10:57 AM
RSBro's Avatar
RSBro
I posted my results in the "What Did You Do To Your Porsche Today" megathread, part nos. are there. With labor, would've been probably an $8k+ job. $0 cost because was under CPO. Replaced the entire bladder system AND control unit, as both were failing. Not looking forward to having to fix that myself in the future...
Old Jun 30, 2025 | 11:38 PM
PorscheUnleashed's Avatar
PorscheUnleashed
Sorry to bring up an old thread but where is the fuse located? I think I might have the same issue. Compressor doesn't even try to kick on
Old Jul 2, 2025 | 04:32 PM
H2Owon's Avatar
H2Owon
The fuse for the front spoiler compressor is located in the left footwell fuse box. Specifically, it is a 30 Ampere (A) fuse designated for the "Front spoiler control unit". You can find it in Row C, position 7 of the fuse box in the left footwell.
Old Jul 2, 2025 | 05:14 PM
PorscheUnleashed
Thank you!
Old Jul 4, 2025 | 12:47 AM
PorscheUnleashed
Fuse blew again after it inflated the front aero 3 times.
I guess I'll pop open the box and replace the air pump to start. Thanks for the help again
Old Jul 4, 2025 | 02:40 PM
mffarrell's Avatar
mffarrell
I would bench test the pump before you replace it. You could have a bad control module.
Old Jul 4, 2025 | 07:30 PM
E Allen's Avatar
E Allen
This was exactly what mine was doing. I replaced the complete control module box and it works like new now.
Old Jul 6, 2025 | 01:11 PM
PorscheUnleashed
Yeah it's an issue with excessive resistance I'm sure. If I'm lucky it's just something simple like old soder points getting weak over time causing a poor connection.
Did you happen to pop your old one open to see what there was to see?
Old Jul 6, 2025 | 01:40 PM
B Russ's Avatar
B Russ
What did that cost and where did you get the part
Old Jul 7, 2025 | 04:57 PM
E Allen's Avatar
E Allen
I did, the pump had a lot of black dust from the bladder breaking down so I think it was clogging the pump up over time.
Old Jul 8, 2025 | 12:41 AM
PorscheUnleashed
Yeah my bladder (plastic bag inside the box) has a bunch of black dust in it. I tried giving the pump 12V directly to see if it would power on from a battery I had and it immediately started smoking lol. No wonder it keeps blowing fuses.
The pump is a discontinued part and unobtainable through retail channels. I am working on a different pump and am going to make a replacement and then try it out. If it works I'll try and offer a rebuild kit or service to people. This thing is incredibly simple, crazy they charge what they do for it lol.
