Pressure sensor issues
Hey guys, having some trouble with my 911 hope you guys can help out
I have a 991.1 Turbo S and I’m having a shop install a Dodson Clutch. Whats happening though is after install the PDK will not calibrate and im getting a few codes for pressure sensors. The codes are
POB41
Pressure sensor1 (clutch 1), signal implausible (Signal error)
P0846
Pressure sensor 2 (clutch 2). signal implausible (Signal error)
P1775
Protective measures cannot be performed (No fault symptom)
7101A
Pressure sensor 1/2 - signal implausible (No fault symptom)
P1870
PDK control unit - incorrect calibration (No fault symptom)
After installing all new pressure sensors It threw a different code right away for pressure sensor 1. Took it back apart, swapped the original pressure 1 back in because that didn’t give us a fault originally we were only replacing it as a precaution and the same pressure sensor 1 fault is there.
Have any of you ever dealt with this on a pdk? Any suggestions?
POB41
P0846
P1775
7101A
P1870
