No boost Please help
I have a 2016 911.1 tts with an AIM 750 kit and tune and a sprint booster (bought 2nd hand). Car ran and drove as expected for over a year. A week ago i put the sprint booster in valet mode to leave car to get paint correction (but i dont have the 3 digit pin to put it back to normal) I'm now getting only 1-3 lbs of boost. I get an engine fault code P0068 Permanent MAP/MAF - throttle position correlation.
So far I've tried 1- erasing code with Icarsoft. Code Keeps coming back
. 2 - erase code and remove sprint booster, code keeps coming back
. 3 - erase code, remove sprint booster, pull tune from car, and disconnect battery for 30min - code keeps coming back.
I'm at my wits end. I have a super car with about 250hp HELP PLEASE
Check the vacuum - boost tubes. I had all of them tie-wrapped and snugged.
Sounds like electronic actuators of one of the turbos has failed.
It wont boost pass 0.3 bar.
Safety measures by ecu to not allow either turbos to boost.
p/s: Why do you need a sprint booster kit when you already have AIM 720kit with tune?
Thats my experience.
Simple check would be to see if the actuators are stucked, by jacking the car up and pushing on the actuator bar itself?
The same issue occurred on my upgraded turbos a few months back and it ended up being the actuators.
