Another PCM3.1 CarPlay Kit Installed
After checking various threads on this forum and viewing YT videos, I decided to install the NM Automotive PCM3.1 Wireless CarPlay kit with compatible reverse camera. Got my local tuner's audio tech to install on my .1TTS though they're familiar with other brands (GTA, JoyeAuto, etc) but not NM. These kits involve replacing the sub-board (circuit) and ribbon connectors inside the PCM to activate wireless connection on Apple/Android phones. They come with plug&play wiring harness that connects like OEM to system. Some differences among the brands - the NM kit takes power directly from PCM connector (no separate fuse box link); and doesn't require tapping onto reverse lights for backup camera.
Unboxing the NM Auto CarPlay kit
The NM integration was seamless and supported by a detailed & clear instruction manual plus excellent customer service from the main man himself, Nick Marquis. Initially encountered a hitch after first install as the audio tech missed some notes from the manual. Nick assisted and clarified that - their bespoke color-coded ribbon connectors were required in lieu of the OEM ribbons inside the PCM, and also the black reverse cam wire needed proper grounding at the rear of the car.
Bespoke PCM ribbon connectors, color-coded
Proper sub-board location of ribbons
The kit is high quality and operates brilliantly. Despite the dated PCM3.1 unit, the clarity of my iPhone's CarPlay screen is excellent. Even the reverse camera is more than decent.
It's a great product. Though pricier than its rivals, the NM Auto in my view is worth it given the build quality, integration, seamless operation and ease of installation. Again, a shout out to Nick for his outstanding support. Here's a very happy camper!
Now my 991.1TTS is just missing the 20Hp grunt and the rotary drive mode dial on the SW of its .2TTS sibling. Ha, ha...
DCsTTS (01-09-2024)
Add a board. Press Info key for a few seconds to flip between PCM and new unit.
The limitation is that volume plays through the Aux connector, so if listening to CD or Sat radio, you won't hear warnings on Waze.
I installed one of these for a friend, and it was very easy. I've also installed the 9xxresearch.com (based in Atlanta vs. the UK) unit. They are basically the same, but you need to take the faceplate apart to swap the cable in one but not the other.
There are several ways to route the camera. There was a recent thread on the 997 side that offered some interesting ideas.
@Foosh @Wayne Smith : Yes, I stand corrected - means added a sub-board. Kit retains PCM functionality.
Foosh (01-08-2024)
Opinions are all over the map on the best option for CarPlay. There are many ranging from new head units to adding boards and modules.
I used something called Mr12Volt, which adds the board, plus an external module that fits under the dash next to the steering column. It also keeps 100% PCM function. When I was researching, it was only one I saw that provided digital audio output. Other solutions are analog audio, which requires conversion of the digital signal to analog, which does degrade sound quality.
http://acsbyroman.com
DCsTTS (01-09-2024)
Rocky Mountain High
I am potentially interested in this modification. Does the Mr12Volt product allow you to use the car’s voice control button to activate Siri?
Dennis C (01-09-2024)
Basic Sponsor
I'm happy to answer any specific Mr12volt questions you guys might have.
Modernize your P-Car w/ Mr12Volt. Apple Carplay and Android Auto with superior audio quality, features, and support. Reach out for specials! Torque.Acs@gmail.com or Roman (267) 317-8229
Our website is now LIVE! please visit us at www.ACSByRoman.com
COUPON CODE "toys" FOR FREE INSTALL KIT!
On site install is available in the Philadelphia PA area as is Global shipping!
CLICK HERE JOIN OUR FACEBOOK GROUP
Rocky Mountain High
My car is a 2014 model with PCM 3.1. My only questions are:
1. Does the voice button activate Siri (my car has the optional voice command function).
2. How do you switch between normal PCM and CarPlay?
3. Is there a wireless CapPlay option or is it only wired?
Basic Sponsor
2)you can press the source button at any time. You will see am/fm/sat/tv. TV is mr12volt.
3)mr12volt is Wireless for carplay and android auto but you can still use the USB plug if you like.
Order from us (acsbyroman.com) to make sure you get the correct standoffs and tools.
Rocky Mountain High
1) siri is voice activated. Not by a button. The button still activates your pcm voice control.
