ScorchTV's - ByDesign XR-EvoSpec Build
#31
So nice.....
Thats one of my only issues with this platform is that when you "pop the hood" you cant see any of the engine or nice parts like you can with a regular front engine car....
#33
Part 3 - Intercoolers and IC piping
After a ton of research and results I decided to go with the AMS intercooler! It is just head and shoulders above my old intercooler and others I have seen in the market in construction, core, and overall flow path.
![Name: SaDRPxQ.jpg
Size: 902.0 KB](https://rennlist.com/forums/attachments/991-turbo/1337812d1683241931-scorchtv-s-bydesign-xr-evospec-build-sadrpxq.jpg)
![Name: txXg2dG.jpg
Size: 823.3 KB](https://rennlist.com/forums/attachments/991-turbo/1337813d1683241931-scorchtv-s-bydesign-xr-evospec-build-txxg2dg.jpg)
![Name: fEk26FU.jpg
Size: 1.54 MB](https://rennlist.com/forums/attachments/991-turbo/1337814d1683241931-scorchtv-s-bydesign-xr-evospec-build-fek26fu.jpg)
AMS Garrett high density core
![Name: 6pYX51W.jpg
Size: 1.80 MB](https://rennlist.com/forums/attachments/991-turbo/1337815d1683241931-scorchtv-s-bydesign-xr-evospec-build-6pyx51w.jpg)
Chinese core
![Name: 8Wj6JHp.jpg
Size: 1.67 MB](https://rennlist.com/forums/attachments/991-turbo/1337816d1683241931-scorchtv-s-bydesign-xr-evospec-build-8wj6jhp.jpg)
Smooth transitions and flow path
![Name: LFRTLdj.jpg
Size: 1.37 MB](https://rennlist.com/forums/attachments/991-turbo/1337817d1683241931-scorchtv-s-bydesign-xr-evospec-build-lfrtldj.jpg)
Abrupt end tanks
[img]https://i.imgur.com/rHqDnXy.jpg[/img]
old intercooler
[img]https://i.imgur.com/c0MPrUN.jpg[/img]
8” wide on old intercooler, less surface area when compared to AMS Garret Core
![Name: HJL8KmI.jpg
Size: 1.86 MB](https://rennlist.com/forums/attachments/991-turbo/1337818d1683241931-scorchtv-s-bydesign-xr-evospec-build-hjl8kmi.jpg)
5” thick core on new AMS Intercoolers
![Name: iwnA3jy.jpg
Size: 1.51 MB](https://rennlist.com/forums/attachments/991-turbo/1337819d1683241931-scorchtv-s-bydesign-xr-evospec-build-iwna3jy.jpg)
8.5” wide on new AMS Intercoolers = more surface area.
![Name: WOppcng.jpg
Size: 1.83 MB](https://rennlist.com/forums/attachments/991-turbo/1337820d1683241931-scorchtv-s-bydesign-xr-evospec-build-woppcng.jpg)
Even the ducting is all cleared CF and well thought out on the AMS
[img]https://i.imgur.com/WeTqPM5.jpg[/img]
Old Intercooler ducting unfinished carbon is what is seen from outside of the car. smaller ducting area.
![Name: 9QKaqWl.jpg
Size: 1,018.3 KB](https://rennlist.com/forums/attachments/991-turbo/1337821d1683241931-scorchtv-s-bydesign-xr-evospec-build-9qkaqwl.jpg)
finished carbon you can see through the rear exit. you can also see how much bigger the ducting is.
![Name: WT5ghKu.jpg
Size: 1.00 MB](https://rennlist.com/forums/attachments/991-turbo/1337822d1683241931-scorchtv-s-bydesign-xr-evospec-build-wt5ghku.jpg)
AMS on the left
![Name: w3o3zpY.jpg
Size: 939.9 KB](https://rennlist.com/forums/attachments/991-turbo/1337823d1683241931-scorchtv-s-bydesign-xr-evospec-build-w3o3zpy.jpg)
AMS on the left
![Name: iTKlpro.jpg
Size: 1.71 MB](https://rennlist.com/forums/attachments/991-turbo/1337824d1683241931-scorchtv-s-bydesign-xr-evospec-build-itklpro.jpg)
[img]https://i.imgur.com/6AE3g0p.jpg[/img]
When it came to the Y-pipe i went with the tried and proven IDP Y-pipe but made several modifications to be different and net some more HP out of it.
We added 2 Tial BOV to it to expel pressure when the throttle is closed.
We added 2 Methanol bungs
We smooth out the inside a bit and increase the internal diameter
Lastly we added Vibrant Vanjens to secure everything.
After this was all done I hand polished the pipe and sent it off to Anodizing to match my Bydesign Intake Manifold and Plenum.
![Name: xA7jJ2O.jpg
Size: 1.45 MB](https://rennlist.com/forums/attachments/991-turbo/1337825d1683241931-scorchtv-s-bydesign-xr-evospec-build-xa7jj2o.jpg)
![Name: uL19LHv.jpg
Size: 4.03 MB](https://rennlist.com/forums/attachments/991-turbo/1337826d1683241931-scorchtv-s-bydesign-xr-evospec-build-ul19lhv.jpg)
Final Result!
Attachment 1337827
Attachment 1337828
![Name: SaDRPxQ.jpg
![Name: txXg2dG.jpg
![Name: fEk26FU.jpg
![Name: 6pYX51W.jpg
Chinese core
![Name: 8Wj6JHp.jpg
![Name: LFRTLdj.jpg
Abrupt end tanks
old intercooler
![Name: HJL8KmI.jpg
![Name: iwnA3jy.jpg
![Name: WOppcng.jpg
![Name: 9QKaqWl.jpg
![Name: WT5ghKu.jpg
AMS on the left
![Name: w3o3zpY.jpg
AMS on the left
![Name: iTKlpro.jpg
![Name: xA7jJ2O.jpg
![Name: uL19LHv.jpg
Final Result!
Attachment 1337827
Attachment 1337828
#34
Basic Sponsor
That came out awesome! Everything is next level man nice work!
Proud TOP Porsche Distributor For:
Kline-Innovation - ams Performance - TiALSPORT/XONA - #1 COBB PRO TUNER - CSF - IPD Plenums - DO88 - dodsonmotorsport
310-600-1850 - sam@bydesignauto.com
#35
That is damn impressive; that anodizing is to die for.
#37
#40
Pretty sure that exhaust mod would get you arrested here in Vancouver...
#41
#43
This is my baseline dyno we are well north of that ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Couple of things to note:
- we are seeing spool-up about 750-1000rpms sooner than with my previous kit and a lot smaller turbos. Just goes to show what an actual quality kit will do.
- the power never drops off up top, just keeps wanting more.
![Name: 1lRi7kM.jpg
Size: 784.5 KB](https://rennlist.com/forums/attachments/991-turbo/1337694d1683241852-scorchtv-s-bydesign-xr-evospec-build-1lri7km.jpg)
RadarP3C (03-27-2022)
#44
Most certainly a very healthy start, bravo, and, damn impressive!
