Help me with weight loss.
All this will be for naught as the real issue here is that you need to personally bulk up my friend...
CodyzWorld (12-22-2021)
Well ditching passenger/rear seats would be a start. Get rid of the PCM, carpet, door cards, frunk carpet, tire inflator, plastic bits in the engine compartment, stock wheels, stock tires, stock hood...
Question: does anyone have any 1/4 mile or 60-130 before and after dropping the weight?
TBH, I’ve always just accepted that the TTS would be a bit portly, but I didn’t expect a strong return on investment from dropping weight on this platform unless I went really hardcore. On my track cayman, I pulled close to 10% out (including lithium battery) which made a huge difference considering it has less than half the HP. But the car is obviously unusable on the street.
Thanks in advance
Thanks in advance
The following 2 users liked this post by .2PDK:
NightBlueTTS (12-22-2021),
ottodawg (12-22-2021)
Our cars are much heavier than we think. At Pitt Race I weighed in at 3,664 lbs with me, a 1/4 tank of gas, GT3 rear seat delete, Kline Inconel turbo manifolds, test pipes, Inconel exhaust, and GT2 carbon buckets.
Yes, I understand that adding boost/HP is the key to make better ET's but that's not the only thing.
McLarens accelerate so fast as they're mostly sub 3K lbs.
My prior car was a 16 GTR Nismo. A fellow Nismo owner spent high dollars to go from 3850 stock to 3400.
While simply adding more power is a simple solution, getting rid of weight would make things much more amplified.
My predicament is what to sacrifice and what not to. For example, my best friend sits in the back of the TTS, so removing the rear seats will not be an option.
Basic Sponsor
@CodyzWorld
HRE R101 Lightweight's. They will significantly reduce unsprung weight when replacing your relatively heavy OEM wheels with these. They top the scale at 17.2 lbs each front and 20.3 lbs each rear. And the cherry on the top is how amazing they look.
![](https://live.staticflickr.com/4542/24292420268_3f6dbd83d5_h.jpg)
![](https://live.staticflickr.com/4466/38144401541_4039278ea4_h.jpg)
![](https://rennlist.com/forums/signaturepics/sigpic163826_2.gif)
Wheels Boutique // 786 249 0127 // Sales@wheelsboutique.com
Follow us on YouTube: www.youtube.com/user/WheelsBoutique
Largest Dealer In The World for HRE Wheels, ANRKY Wheels, Vorsteiner Wheels & Aero, Akrapovic Exhaust, & iPE Exhaust
BBS, Forgeline, & TechArt Premium Dealer
Brembo / Rotiform / KW / H&R / Novitec / Brabus / Mansory and tons more...
i did HRW LW, anti gravity battery and kline inconel. i think it shaved 100 lbs or so. not sure what i gained back with the xr setup, ic's and intercoolers.
![](https://cimg4.ibsrv.net/gimg/rennlist.com-vbulletin/920x2000/8f95c7c0_1571_498e_89d7_ef6fe92fc168_f334fe6e590792f816d7fef1dc097ef64ab2c0bb.png)
What do you imagine I’m gaining by stripping the car?
The very first pic of the 'What did you do to your 991 today thread', I was weighing in at around 330+ lbs.
Today, I am at a touch over 220, 6'3".(Christmas and bourbon have brought me up from 215, which will be rectified in January).
I figure that is good for at least a 1/10th in the quarter...
CodyzWorld (12-24-2021)
